600 planter/valves in hyd. system
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: 600 planter/valves in hyd. system
    Posted: 09 May 2011 at 7:22am
Just wondering what the purpose is for the gate valves in the lift circuit of the hydraulic system on my 600 planter frame. The former owner said he would open them every so often when one frame would get out of sync, cycle the hydraulic lift circuit a few time till the frames evened up, close them again and run it with them closed. Is this the proper procedure? Any reason to not run it with them open all the time? Any ideas? Thanks, Darrel
Farmer Roy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farmer Roy Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 7:29am
The owner told you right.  If I remenber correctly, it will be the right side of the planter thats wants to drift down.  hope this helps.
jhill52 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhill52 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 7:51am
The former owner is right. Under normal conditions the left cylinder forces the right one up causing it too lift evenly. If you leave them open the lighter side will raise first. The second valve is the transport and storage valve.
NEJim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEJim Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 1:01pm
That's right they are to level the planter.  Had one for years and it went to South Dakota I beleive.
