D17 Power Director question/ problem??
allis restorer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis restorer Quote  Post ReplyReply Direct Link To This Post Topic: D17 Power Director question/ problem??
    Posted: 08 May 2011 at 9:17pm
The power director on My D17 series 1 dosent stop when in the netural postion, if i hold the brakes real hard it stops. Even when the tractor is warmed up and it being 70 degrees outside it still dosent want to stop. it has done this since ive gotten it and i though it was maybe because it was cold outside that it wasnt working. Any help appreciated, thanks Steve
Go orange or Go home!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 9:21pm
I've been told that it's normal for them to want to creep especially when the oil in them is cold.
Rayhowling View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rayhowling Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 9:35pm
My 180 Diesel started to not want to move very much at idle speed last fall. When gathering sap to make maple syrup this spring it got worse.a week ago we split the tractor to get the power director out and we had put all new disc plates and new seals in it 2 years ago. They looked to be in good shape and put it back together and it still was slipping. We than took the control that switches from high to low range apart and cleaned it up. It works okay now but wants to creep in neutral. Does it need adjusting in the high low shifting box?
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 9:43pm
Sounds like someone else did a "repair" job on it, either pulled shims or put in new discs, and didn't re-shim it properly.  My best guess.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 9:47pm
Plates broken in PD or return springs broke or nutural notch out of adj. Put hyd wet brake oil in it.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 9:57pm
When I was kid on farm none of our tractors would creep in nuetral.I have climbed on an awful lot of A/C's since and most creep.My Ser.I creeps, but the Ser.IV does not.Some old timers at auctions and shows have told me if you went out and plowed all day it would take care of that.I don't know,probably in shims and adjusting power director.
This page was generated in 0.158 seconds.
