The #%$& Hit the Fan
HansNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HansNE Quote  Post ReplyReply Direct Link To This Post Topic: The #%$& Hit the Fan
    Posted: 08 May 2011 at 2:47pm
Well not exactly,  actually the fan on my D17 hit my radiator.  I had come to a stop on an slight uphill incline with a sprayer behind the tractor.  Engaged the brakes and as I was getting ready to step off, the brakes came free.  I quickly sat back down and in braking ended up only hitting one brake.  Anyway, in the excitement and coming to a quick stop, one of the fan blades nicked my radiator up top so I had anti-freeze spraying everywhere.  I can't figure out how one fan blade could nick the radiator.  Everything seems tight with no movement.  Something has to be loose however.  Any ideas other than only stopping on level ground?
Hans
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 3:33pm
Check for cracks/flex on the blades...one might be getting ready to break off.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 3:41pm
Well either the fans a tad loose or the rad is.....
Maybe that one blade was a bit bent ???
Fan not sitting square on shaft ???
just thinking out loud....
zootownjeepguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zootownjeepguy Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 8:01pm
I'd check the fan bearings, or water pump shaft if that's what the fan is attached to. I once had a Silver King with worn fan shaft bearings and the fan made a nice round imprint on the radiator core and bored through half of the tubes.
Most likely the radiator and hood moved just enough from the impact to catch a blade.
Edited by zootownjeepguy - 08 May 2011 at 8:04pm
Rich Salvaggio
'31 Allis Chalmers U 7143
'46 Willys CJ2A Farm Jeep
'48 Caterpillar D2
Antique Garden tractors
*Other rusty old junk comes & goes without notice
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 9:45pm
Had my 45 throw a blade yrs ago.Got seven tubes on the recent recore.OUCH!
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 5:57am
Geeze, Hans... I just pulled the radiator on my Ser 1, and there didn't seem to be any really 'tight' clearance points... the cracked blade shouldn't be a hard thing to see... so I guess the next thing I'd look at, would be the front bolster bolts and then the framework... mebbie the front engine mount bolts.  Obviously something shifted... but from what I saw on mine, it'd take a lot of shifting in order to cause a problem...
