'39 B timing marks are gone.?
Mark in Iowa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark in Iowa Quote  Post ReplyReply Direct Link To This Post Topic: '39 B timing marks are gone.?
    Posted: 08 May 2011 at 12:50pm
Suggestions on how to time if timing marks are worn off of the fly wheel of 1939 B.
     Thanks, Mark
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 1:16pm
Do it like the old timers do it ---by ear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark in Iowa Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 7:37pm
I need to get tractor/governor set so when I put the rebuilt FMJ mag on I have a match for the firing order with the mag. Not sure how to do it without the marks on the fly wheel to go by Thank
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 8:32pm
Take the spark plugs out. Put your thumb over spark plug hole number one(closest to the radiator). Have someone hand crank the engine until you feel pressure on your thumb. That is when #1cyclindar is TDC and ready to fire. Align mag rotor to #1 wire (top left) Install mag and wires and plugs. It should run. Fine tune by ear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 10:30pm
The marks are there, they're just not stamped in very deep. Rust can hide them. Do like Ted says.
This page was generated in 3.257 seconds.
