Looking for Corn planter plates
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Topic: Looking for Corn planter plates
    Posted: 08 May 2011 at 12:03pm
Looking for 4 corn plates for this planter... think its a 500 series. Also, the seed boxes say "beet and bean" on them. Would I have any problems throwing corn plates in, and planting corn? Questions from a rookie! Thanks!!
Also, if someone has pictures of the front area with the fertilizer attachment assembly, that would help alot!
Here are my seed plates, I have the soybean plates. Could I change these plates to use temporarily for corn?
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 12:52pm
Your population would be way too high planting corn with bean plates. If that is the shape of your plates I may have some. Do you know what size you want?
Gary IN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary IN Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 12:56pm
Also have some if your still looking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 1:13pm
Not really, what are my options for size?
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 1:16pm
It depends on your seed size and shape from small rounds (34-39#/unit) to large flats 59-65# per unit.
jhill52 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhill52 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 1:38pm
Those plastic centers are adaptors for John Deere plates. Should be readily available. I have the same setup on my 600 series. I have a manual if you need more info.
Make sure the seed knockers are working freely.
I am over by Caro not to far from you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhill52 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 1:43pm
Looking further i think the planting munits are no 72's only the boxes are Beet and Bean. come look at mine if you want.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 1:58pm
Jhill I might take ya up on that offer. Maybe a week night this week. PM'd ya.
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 2:50pm
Go to lincolnagproducts.com. They have a complete line up of JD B plates that will work with the adapters you have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 8:16am
Don, I don't have any sets of the JD B plates in plastic, I do have a few sets in steel. Sorry I couldn't help you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 11:14am
No problem John. I will check with gary. Thanks!
On a side note, does anyone have the front bar with fertilizer attachments that I would need?
You can see in the picture, that I would need everything from the hose off the fert. box downward.
Also, I found out this is a model 505 planter, beet and bean. CH wendels book.
This page was generated in 0.093 seconds.
