WD45 draw bar
WhiskeySup View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WhiskeySup Quote  Post ReplyReply Direct Link To This Post Topic: WD45 draw bar
    Posted: 08 May 2011 at 8:57am
With the 3pt hitch on the tractor, can I also attach a draw bar?
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 11:14am
If you do the three point sway bars will hit the drawbar bail when raised. I have the same setup on one of my WD45s. If you take the sway braces off it should fit with the drawbar just over the cross brace and the bail in the second hole from the top. at lest mine fitts like that. since that is a shop built adaption its a good maybe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WhiskeySup Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 12:21pm
Thanks Dave, I was afraid of that. the grand daughters are wanting hay rides so I better get busy on a fix.
Dale H. ECIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale H. ECIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 12:52pm
You can put the Ford type draw bar on the 3 point balls. They can be bought at any farm supply store.
Allis Chalmers Museum, Paris, Il.http:// www.allischalmersmuseum.com 217-275-3428
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 11:03pm
Here is what mine looks like.
