belly mower pulleys
cabindawg7279 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabindawg7279 Quote  Post ReplyReply Direct Link To This Post Topic: belly mower pulleys
    Posted: 05 May 2011 at 9:42am
My belly mower is down and the grass is growing like mad. I need to replace a dual
v belt pulley 7 inches in diameter to fit 2 7/8 inch v belts(C).It's a tensioner pulley with center bearing.  Any suggestions as to where to look?...most places I've tried don't care anything that big. It's off an old Danco belly mower for my "B". Any suggestions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 2:43pm
Try Motion Industries. They have about anything needed. Also McMaster Carr. HTH Tracy Martin
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 9:30pm
Danco mowers were used on International Harvester equipment. When I needed blades for mine I went to an IH dealer and he had them in stock. Mine had 5" idler pulleys on it. You my not need that large of an idler. Bob
E7018 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote E7018 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 9:37pm
I would go for a walk in the combine salvage yard. Can you use 2 single groove idlers?
