Are some years model B's better than others?
Protrucker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Topic: Are some years model B's better than others?
    Posted: 04 May 2011 at 7:41pm
I accidentally posted this in the wrong place, so I'm re-posting it here to get more response.....I hope.
I have become interested in getting an A-C B. I've been looking at a lot of info & it has become apparent that the 1939 B is more desireable (at least around here) for some reason. Is a 1939 really the best production year to look for? What's that reason?
Is there really much difference between the different years? What should I look for in an A-C B, possible problems to look out for, etc when looking at a prospective purchase?
Lot's of questions, but I appreciate any help.
Thanks,
Al
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 7:58pm
I prefer the later years with a PTO, HYD, foot brakes, and electric start. Hand cranking is a pain. 1940 and later. Most rare and desireable is SN 1-97
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 8:03pm
Look out for worn splines (rear axel) and rear wheels. Expensive to fix.
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 8:12pm
Depends on your preference. I prefer a B with a CE engine. It's got a bit more horses under the hood and the ones with the CE engines usually have electric start and sometimes lights, which are more useful then you think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 8:22pm
1939 was the year for the highest production of the B with almost 22,000 built. The most desirable collector B, I would say would be the 1937 Waukesha because of the low numbers produced.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 8:24pm
I would rather have a later one with hydrolics, PTO, electric start, and foot brakes like said above I dont see a reason to want a early one without those options "unless it was just for show" but thats just my opinion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 8:25pm
Here's one that's for sale, not too far from me. I haven't called about it yet. Any Idea what year it may be & what it might be worth?
allis-chalmer B tractor in excellent condition, everything on this tractor works great(lights,gauges, pto, hydro. lift and remote). Two new back tires.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 8:34pm
I agree with those above.  Really the only difference in the B tractors was (1) the early ones with the waukesha engine (very rare) (2) the later ones after 1942 - I think - that had foot brakes and electric,  Other than that they are basically all the same.  Even the older ones with the smaller engines have usually been rebuilt with the larger sleeves.  Also, Hydrallics can be attached to just about any B.
Good tractor.  My favorate.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 8:40pm
the one in the photo above appears to have an adjustable front axle. MOst had the wishbone front end. The adjustable would be worth a few bucks more. Also appears to be painted. THat might mean the motor / rear were rebuilt... maybe. If rebuilt, the price is about $2000.  If just paint covering an old tractor, then $1000. if the tires are good and it runs decent.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 8:49pm
Does that B in the pic have 5 bolt rear hubs? It looks like it but I can't see it that well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 8:55pm
Looks like 5 bolt rear hubs to me. That is desireable and makes it a late model.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 9:21pm
Having good rear tires is a big plus. Tires just keep getting higher and higher priced.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 9:28pm
I don't think it's a late B because the starter switch is still on the bottom. They did have some 5 bolt adapter hubs that fit over the splines. I have a late '39 with an adjustable wide front and it has a 5 bolt adapter on one side. I'd like to find another one and a 5 bolt center to fit it. The centers are more like a regular B center than a dished C center.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 10:25pm
bump
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 5:33pm
Well......I missed this one!
I called today & it was already sold. He got $1400 for it. I asked if he just did a cosmetic restoration or full resto. He said that he just painted it & put on new guages, etc. but it ran & functioned great.
Oh well, I'm still in the learning process & still trying to make up my mind exactly what model tractor I want. I don't want to spend a ton of money getting started. I'm planning to use the tractor to plow, plant, cultivate & harvest produce on a sort of small scale for now until I see how it goes marketing what I grow. So far, I've been just using my old Ford & Case/Ingersoll garden tractors, but they arent really big enough to pull my potato digger easily.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 5:56pm
The reason that you see so many 1939 tractors is that was the biggest year 20,000+ Bs made that year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 6:52am
I prefer the later B's over the real early ones myself. PTO, electric start, etc. like Ted mentioned. My B is a 48', and the IB is a 49'. Although there is a 39' that's in pretty nice shape sitting under the big Pine tree to the side of the barn that I know of....
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 7:02am
The one in the pic was a good buy I think, what can you get for 1400 ? Like others said electric start is great.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 7:04am
........ Not much longer.....  better move fast!
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 8:06am
I'm pretty sure the later B had a better steering gear box that made it easier to steer. I don't remember which box was which but one was a Ross and the other I think started with a G.
Wink
I am a Russian Bot
1946WP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 8:15am
you snooze you loose' I think that was a good buy, i wouldn't sell mine for $1400. & it's basically the same thing.
