Correct tire size for WD45?
Dwayne TX View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dwayne TX Quote  Post ReplyReply Direct Link To This Post Topic: Correct tire size for WD45?
    Posted: 04 May 2011 at 3:35pm
What would it be?
12.4 x 28?
13.6 x 28?
14.9 x 28?
Not worried about complying with any pulling rules, just what would be a good usable size.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 3:39pm
14.9x28 Maybe if you can get a great deal on 13.6's but I think they look too small. They would be fine for parade duty.
Edited by CTuckerNWIL - 04 May 2011 at 3:41pm
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 3:41pm
They came with 14.9-28s. The WD had 13.6-28s. Either size would work well on a WD45. If you have to get rims too adn are not worried about being "factory", alot of older combines have 8 bold pressed steel rims that will fit. A 14.9-26 will put the same amount of rubber on the ground as the 13.6-28.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 4:38pm
yes, 14.9-28 is correct but they sure look nice with 16.9-28 on them.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 6:17pm
Ditto what Matt said.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 8:10pm
My operator manual lists 12X28 as the correct tire on a WD45.  on the miller tire crosreferacne that is a 13.6X28. I put 14.9 X 28s on both my WD45s. as the 13.6s look smaller than the old 12X28. and 14.9s look Bigger than old 12s
BurtIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BurtIA Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 8:28pm
The two new 45's we bought in '54 and '55 came with 13x28's which would equate to 14.9 these days. The new '51 WD came with 12x28's which would equate to 13.6 now.
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 9:40pm
Got 14.9s on Mine, good-year duratorques.  Would have liked 16.9's but the price increase was not worth it for a show tractor.  Still looks good with the 14.9's
