6080
walkerb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote walkerb Quote  Post ReplyReply Direct Link To This Post Topic: 6080
    Posted: 03 May 2011 at 7:52pm
Will a 6080 with the thrust bearing stand up to heavy PTO work?I am thinking of putting it on a 15 foot batwing mower which can drive hard in thick ,fine grass.All opinions are appreciated.Thanks in advance.
Russ SCPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ SCPA Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 8:18pm
15 footer could be a mite much hog for a 6080, I can "lay down" my 7020 with a 12 footer in big stuff.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 8:33pm
It depends on what you're mowing.  We use a 3240 20ft HD woods batwing on our Ford 6610 (72 PTO HP), but you better be just trimming a pretty flat pasture when using that tractor, or you won't be mowing much fast.  I think a 15 ft batwing would be a good fit behind an 80ish PTO hp tractor in most field conditions.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 8:37pm
Using the PTO don't hurt the thrust bearing, it's using it with the PTO lever on your right side pulled back for long time. When PTO is not being used disconnect PTO lever on left and engauge the one on right.   MACK
