D17 transmission gears
terryinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote terryinmo Quote  Post ReplyReply Direct Link To This Post Topic: D17 transmission gears
    Posted: 03 May 2011 at 6:38pm
Has someone on here had any experience with the new gears that  A&I Products have? We have a third gear jump and need to fix it serial#33289 . Any help would be appreciated.
se iowa picker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote se iowa picker Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 9:21pm
This may seem a different take on it but have you checked your shift rails for jumping out of gear? We have a series 4 D17 and had a lot of trouble with it jumping out of road gear. Well one day the shift rail broke and when we replaced it we have not had anymore trouble with it jumping out of gear. Just a thought.
Post Options Post Options   Thanks (0) Thanks(0)   Quote terryinmo Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 9:15pm
Rail is fine cogs that coupling slides on his worn and gear cogs are pounded.
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 8:58am
We use A&I in ours and they have worked great thus far.
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote terryinmo Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 10:08pm
Thanks just wanted some input good or bad products.
