coil rheostat-gets hot-normal?
Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Quote  Post ReplyReply Direct Link To This Post Topic: coil rheostat-gets hot-normal?
    Posted: 03 May 2011 at 5:01pm
Doing some behind the dash wiring improvement on my AC 210. The light switch has a coil wire rheostat that gets real hot when the lights are turned on. Is this normal? Too hot to touch. What amp fuses should I use-wiring is mostly 12 and 14 gauge. Thanks
realolman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote realolman Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 6:10pm
If it is just a resistor in series with the lights it would get hot... maybe too hot to touch. It seems silly ....why such a thing would be installed... why would you want to dim your lights unless its just the dash lights ... I am not familiar with the lighting on a 210.
I imagine a wire wound resistor would be precisely to be able to take a lot of heat
in building wiring you can put a 20 amp fuse in the 12 and a 15 on the 14 gauge wires
Edited by realolman - 03 May 2011 at 6:11pm
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 8:20pm
To add to the prior correct information. The light switch has 4 ( I think) positions.
1-Off
2-  Dim road lights. Should have one on each side of the fender lights on and going through the resister to dim them and the Orang/red rear road lights should be on and wired through the flasher. It is mounted near the switch on the back of the dash.
3- Bright road lights. Should have one light on each fender on and at full voltage (bright) and the red/orange on flash same as #2
4- Field. All four head lamps on bright, red/orange road lamps off and rear facing work light(s) on.
I can get the wiring order from my 220 if it EVER quits raining long enough to back to the barn.
This page was generated in 0.107 seconds.
