Model B PTO
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Topic: Model B PTO
    Posted: 03 May 2011 at 4:04pm
I know that AC made a sicle bar mower to be driven by PTO. What other implements were driven by the B's PTO ??
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 8:07pm
40 combine
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
PTO rake
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 8:08pm
Orchard Sprayer
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 8:46pm
Also, one has to remember that for an Allis Chalmers hydrallic pump to be installed it was necessary to have the PTO.  There was an opening on the side of the PTO for the pump to fit.  It was a two piston pump.  Within the pto there was a shaft with two cams to operate the pump.  The transmission rear end pto housing acted as the sump for the hydrallic system.  At the time we used 20 w non detergent oil.  Now they use transaxle oil.
The original PTO had a 1 1/8" spline and no opening for a hydrallic pump.  Later models around 1940 had the opening for the pump.  Even later PTO's had the 1 3/8" spline so that it could power almost any PTO equipment for which it had adequate plower.
Sorry I got a little windy.
Good Luck!
Bill Long
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 8:58pm
That's great detailed information, Bill, and stuff I didn't know, thank you. Not windy from my perspective. Take all the words you need to share that kind of detail. There is no word limit here!
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 9:11pm
Thanks to all who have posted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 9:33pm
OK Glenn and other B enthusiasts, I have an early B with the 1 1/4 PTO shaft and no provision for a hydraulic pump. Would it be possible and or an easy swap to put a late 1 3/8 shaft in my B so I don't have to add a coupler to run my Wood Brothers picker?
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 9:59pm
 go get the pto with the 1 3/8 shaft & get your wrenches out can have it done in about an hour.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 5:57am
#3 mower had adapters to run behind the B/C and powered off of the pto also.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 6:14am
Do these CA PTO units bolt up to B's OK? Seems to me Paul B [ does not post here anymore] said it was possible with a "shaft" change or something to that affect. Any thoughts appreciated. I have 2 to sell, was going to "gut" this one for shaft/brearings, etc and scrap balance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 8:07am
Charlie,  If you can find a B pto with the opening for a hydrallic pump and the 1 3/8" shaft it would be an easy change.  I can't do it now but I sure did enough of them.  Also, I do not know for certain if the CA PTO would fit on a B tractor.  Looks like it would fit.
Thinking it through I would not recommend it since the B is not set up for the CA hydrallic cylinders and other attachments such as tractor booster.
Note the double lobes on the cams.  That gave the pump more piston action since on the WD - WD 45 pump the shaft turned faster.  The WD - WD45 was single lobe.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 3:28pm
Anyone have a loose "B" pto shaft to measure? I was interested in knowing length and other Dim's to confirm/deny whether this shaft could be installed in a B PTO housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 3:30pm
It may fit but will the lobes line up.  A B has only two hyd pistons.?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 3:47pm
If I was using it, I wouldn't worry about the lobes since I have no hole to bolt a hydraulic pump to. If a guy wanted a hydraulic pump and had that shaft, just bolt a CA pump to it.
 My next question would be "is the drive gear the same for both B and CA"? If not is the shaft size the same so the gears can be swapped out?
 I was just thinking that the CA had a higher rpm rating than the C and early B I think, so maybe the driver and driven gears were different to make 540 rpm. ???????
Edited by CTuckerNWIL - 04 May 2011 at 3:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 3:50pm
Sorry about hijacking your post Ted, sometimes these things can get a life all their own.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 6:47pm
I don't have a "B" parts book to check part numbers on the gear. I was figuring more for the 1-3/8" feature and less for the pump [assuming the B had no pump anyway]. Looking at pictures the gear is similar, but possibly different tooth count.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 7:11pm
The shaft on a B without cams, prior to 1940, #206732, with 2 cams, 1 1/8", 1940 thru 1950, #211416, with 2 cams 1 3/8", 1951 and after, #224809.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 9:14pm
Charlie,  Check on e-bay.  One finds the most unusual things there.  Few days ago someone was parting out a tractor - I think it was a B - and had almost every part available.
At to attaching it there was a shaft that protruded from the differential.  When we installed a PTO we would attach a slip gear on the spline.  The installed gear has a slot for a small square on the PTO engagement leaver which fit there.  That was the trick to get that square in the right place.  Other than that it installed easy.  Would that gear be the same as a CA I do not know since all CA's came through with PTOs factory installed.
Looks like it would be but I can't be sure.
Good Luck!
Bill Long
This page was generated in 0.126 seconds.
