Pepper for Sealing Leaky Head Gaskets
CORY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CORY Quote  Post ReplyReply Direct Link To This Post Topic: Pepper for Sealing Leaky Head Gaskets
    Posted: 02 May 2011 at 4:34pm
Wasn't there an old wise tell about using pepper to seal leaky head gaskets?  If so how much should you use.  Have a friend that is a tight *** that won't spend the money on his John Deere 4010 and trying to help him out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 4:41pm
We used to use pepper to seal up radiators FOR A SHORT TIME, so we could get a little extended time before pulling it to really fix the leak, I cannot see it sealing a leaking head gasket as they are under considerable more pressure and the engine vibrations keeping it moving about.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 4:42pm
Buy the Stop-Leak stuff they sell at the Auto Store. If the leak is a seep it will work. If you are overpressureizing with the engine idling, dont waste your money. I put some in a 400 Case 15 years ago that is still holding. Used it in a 3.1 GM car that got me 60,000 more miles. It will fix small leaks but won't cure all your problems.
junkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 4:44pm
I have used water glass to seal up a WD that had a leaking head gasket. It seemed to work just fine. Just remember to not run it through the radiator.
ALLISMAN32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALLISMAN32 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 6:23pm
We used the pepper to fix an external crack on a WD block one time, it worked amazingly well! Not sure how it would do on a head gasket that was leaking. Maybe the fellow should junk that Deere now and buy himself something good with an orange hue!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 7:43pm
It's not an 'Old Wise Tale', its 'Wives Tale'.  We only used it for the radiator and if there is ANY amount of pressure on the radiator, it will leak. Horse manure worked just as well...
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 8:03pm
I had a head gasket leak on an 83 Omni Charger with 120,000 miles on it. I put in a tube of that silver powder stop leak stuff from Auto Zone and ran it another 9 years and 100K before it started leaking again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 8:47pm
they have a lot better stuff in the last 4-5 years. Go to Auto Zone and buy a bottle of the  liquid copper head gasket repair stuff made by BARS LEAK.. it is only $10. and works great. Mixes with the antifreeze and you leave it in the system forever.
ac crazy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac crazy Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 8:47pm
bars leak block sealer works..if you use it right..
If i can't fix it i won't.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 8:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 9:33pm
Hmm, mechanic in a can. If it's leaking compression, I wouldn't hold my breath on it holding. I used liquid glass on my Oliver 60 to seal the sleeve O rings until I could overhaul it. Held for several years. I remember Charlie's 2.2 Chrysler and their head gaskets. All the ones I saw leaked externally. The K cars were something else...
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 11:48pm
My neighbor swears by ginger for sealing radiator leaks. put some in his 400 Farmall and old Chevy diesel pickup and sealed them up tight. I saw him put the stuff in his pickup and observed the results, works amazingly well. As far as head gaskets, if he doesn't pry open the pocketbook and just replace it he's wasting his time. I'm not a fan of pouring anything besides oil and coolant into an engine.
Edited by Bill_MN - 02 May 2011 at 11:51pm
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 12:16am
if he's that cheap...tell him to junk that isore and get a real tractor! lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 10:10am
If it is leaking from compression, any sealer would be a waste of time. JMO
MY 2.2 leaked from a water jacket to the outside and was saved, if you're blowing bubbles in the coolant, forget it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 12:10pm
All of the 2.2's I saw looked like a bit of the head gasket blew out and it would leak in a stream out the front of the engine over the distributor...
