SAE 20W oil
jtheise4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jtheise4 Quote  Post ReplyReply Direct Link To This Post Topic: SAE 20W oil
    Posted: 02 May 2011 at 11:07am
Sorry if this is a silly question, but can anyone tell me what today's equivalant to SAE 20W oil is?  I see in my D14 owners manual, that 20W oil is recommended in many of the gear boxes.  Is this just motor oil?  Thanks.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 11:30am
The 821 oil available at your dealer is a better oil than plain engine oil.   It has anti-wear additives for gears and bearings.
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote jtheise4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 11:32am
Ok, thanks.  I actually have a MF1643 and just changed the hydraulic fluid, so I have plenty of 821 sitting at the house now.  I didn't realize that SAE20W was the equivilant to hydraulic oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 11:35am
All the new oils in the Trans-Hyd oils are blended to replace the old #20 oil used for hyd and gear oil of the past. these now have anti-foam, anti-wear, properties that the old oils did not have.
 Same as the mult-grade engine oils now replace the straight weight oils used in engines. Since these old tractors were made progress has been made in oil and in tractors but new oil work fine in old tractors and old tractors work great with the new oils.
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 11:39am
thy still make straght weght oils  20w-30w-40w  not all stores carry them try T S C or a farm fuel supply - yes you can use other motor oils [ 10/30- 15/40]
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 2:58pm
Oh, oh.  You just pulled my string!!!  LOL
There is no such thing as 30w or 40w oils.  The "w" stands for "winter" and specifications for winter oil stop at 25w (not that it's around).
Mark
GTH-L Simplicity
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 4:09pm
Universal tractor fluid or hytran is 20 weight oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jtheise4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 6:25pm
Thanks everyone for the answers.  Got another one...how about the SAE 80EP that is called out for in the transmission?  Is a 75W90 gear oil acceptable?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 9:23pm
 Yes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 9:32pm
And your 821 hytran fluid will work fine in the tranny too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 9:24am
The newer hy-tran oils are great, but because they are so thin the have a tendency to seep through the old gaskets, so leaks are probable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 9:55am
A 20 weight oil is still a 20 weight oil at operating temp.  It's just that the new oils don't thicken as much at cold temps as the old oils do.  In other words, they shouldn't leak much different.
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 9:59am
That is true if you are using it in the hydraulic system. If however, you use it in place of 80-90 gear lube in the tranny and differential, it could find spaces to leak from that 80-90 wouldn't.
Johnwilson_osf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2025 at 2:51pm
Can I hijack this post a little?  I have a Hesston 1160 haybine, that asks for SAE20-20w SE Engine Oil.  The 1160 is a center pivot mower, with a PTO hydrauic pump that runs the sickle.
Is this Hydraulic Oil, or Engine Oil?
What is the modern equivalent I should put into this?
I was always told to get non-detergent hydraulic fluid to fill the pump reservoir, because regular Hydraulic fluid foamed to much, and the non-detergent helped that.
Thank you
John
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2025 at 3:43pm
today ENGINE oils have a lot of addatives related to combustion / gasoline / heat... You would be further ahead with a good HYDRAULIC OIL... Most of them are in the 20w catagory... some are even multi viscosity.. a GOOD oil should not foam... Look at the back of the jug and see that it meets several specs from Allis / Case / Ford / JD / CAT... then you know your getting a quality oil.. If there are no SPECS, then its probably a cheap quality oil...... You can get this at FARM store, NAPA, ow Wal Mart..
BRAND is not important... SPEC should look something like this...
Edited by steve(ill) - 15 May 2025 at 3:47pm
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2025 at 4:02pm
20w oil back in those days referred to 20 weight non-detergent motor oil.
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2025 at 8:20pm
I had a D14 once.  Except for the engine, I used Permatran 821 gold for most everything else. Didn't seem to have any problems.
