Woods L 59 Mower question
craigreavley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote craigreavley Quote  Post ReplyReply Direct Link To This Post Topic: Woods L 59 Mower question
    Posted: 02 May 2011 at 10:24am
I have a woods L 59 belly mower on my C and I need need right and left skid shoes that go on the sides. Mine are worn through with holes. Does anyone have a pair for sale, or know of a source for new ones.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 10:30am
Parts are still available thru Woods. I recently purchased new front wheels for my L306 from the local dealer.
The operators and parts manuals are available on-line at the Woods Website:
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 10:37am
try the dealer locator on the woods site.
they still make them and parts are avaliable.
Our local woods dealer has wear parts instock.
the local John Deere dealer also orders parts for me.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 10:41am
I re shoe mine with an old auto leaf spring hunk.
Post Options Post Options   Thanks (0) Thanks(0)   Quote craigreavley Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 10:44am
That is exactly what I had thought about doing. I have some old broken springs off a 1 ton dump that are the same width, and are close on the curvature. Sandy Lake has them new for 50 bucks each plus shipping. I may try to weld em up, and then if it doesnt work bite the bullet on new ones.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 11:20am
Use the springs.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 11:53am
WOW, what a novel concept, a company stays in business, keeps the same name, supports it's dealers, and still knows how to sell parts????  Sorry to hijack the thread, but venting a little.  :-)
Still in use:
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 7:44pm
  if mower is properly adjusted the skid shoes should not run on the ground!!!!
  woods tells us that also
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 7:56pm
Originally posted by norm[ind norm[ind wrote:
]  if mower is properly adjusted the skid shoes should not run on the ground!!!!
I guess I need to read the manual. How does that work if you don't have the caster wheels up front. I know they are an option.
Post Options Post Options   Thanks (0) Thanks(0)   Quote craigreavley Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 7:12am
Norm, I was sort of wondering about that. Mine run on the groung the whole time, If I get em rebuilt I need to adjust the front wheels to get the skids up so they dont wear out that fast. It did take about ten years to wear them out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 9:54am
If you rebuild them with old leaf springs, you'll probably bet 20 years out of them.
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 10:30am
Sandy Lake Implement has new ones 1-888-252-0656
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 10:36am
I have over a quarter of a mile of road ditch that I mow. I have the caster wheels adjusted for the flat-er yard. When you are to the bottom of the ditch one side runs on the grass with one caster wheel off the ground. Right or wrong I assumed that this is why they had runners on the outer edge.
Greg_WJP_(WI) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg_WJP_(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 1:51pm
I have the same issue as Dick L.  When I mow the ditches the skids on my L306 make contact with the ground.  On a flat surface/yard they don't touch.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 4:36am
I have a set of wheels and a set or runners off Woods I believe. Do you have a picture of what you need? If I get some time I will post picture of what I have if interested.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 5:23am
Edited by Chris/CT - 16 Jul 2012 at 5:24am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 6:28am
The caster wheels are supposed to take the whole weight of the mower.  The skid plates are for what Dick says, when you are on uneven ground it will keep the mower from running the blades into the ground.  You should also have the caster wheels set correctly so that any tree stumps that you might have will travel above the stump.  Don't ask me how I know this...
