Allis G extension
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Topic: Allis G extension
    Posted: 01 May 2011 at 10:13pm
does anyone have the mesurements for the extension that goes in between the torque tube and the front frame? Were thease a factory piece?
Scott(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 12:08am
I've never seen one.
Do you have a picture of an example?
It's a great day!
Best regards,
Scott
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 5:36am
Mine has a homemade on it. You could add whatever you like I suppose. The spindle housings are also "bumped" out with about 4" sq. tubing. The spacer at TT is about 8-10" just looking at from house.
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 7:01am
Have never found anything in AC book.   Have seen several made by present or previous  owners.  Herb
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 7:08am
Once I get my G mobile again( starter issues),I'll be making one for myself.When I get the design right( has to be curved top and bottom),I'll get a friends CNC to pop a few off.Nice thing is once it's in the CNC memory it's  easy to make them.
I'm thinking an 8" long extension is about right ?
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2011 at 9:00pm
If you do it Jay, let me know when and how much.
  Me and my father both stand around 6'4".  That extension would be a godsend.
Skuter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skuter Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 1:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skuter Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 1:56am
Just put one on two weeks ago, had it made at a local machine shop.  Works great but I need to grow longer legs.  Measured from top bolt centers and bottoms.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 6:18am
Look's well done. How do you like those rolling cultivators? Are they the AC issue units? PS. Did you also space the spindle housings foward?
Edited by Chris/CT - 03 May 2011 at 6:19am
oldironguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldironguy Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 7:34am
This thread speaks of these extensions as an operator comfort feature.  Are they needed to provide clearance on some implements? If so, which implements?
Thanks.
singingpig View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote singingpig Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 7:21pm
Thanks.
They were to provide clearance for for certain implements...for example the buddingh basket weeders in the photo above.
Bill Long View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 7:36pm
Stretching the G as is being done here is fine.  However, we had some problem with we put additional spools between the axle and wheel to widen the G.  If I recall we did this for about 8 inches.  In fact, it was factory authorized.  When the widened G was put to work, and I am not sure how hard the work was the axles continually broke.  Since this was factory authorized we replaced under warranty.  The breakage became so often that we eventually recommended to the customer and the factory that the warranty work be discontinued.  It was costly for the customer - down time - and frustrating to us since we were in the middle of a very busy summer season.
I was in college at the time so I do not recall the final outcome but it may be wise to carefully consider before taking action to widen the G.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skuter Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2011 at 10:58pm
No, the Buddingh Basket weeder isn't issue (that I know of), they're still in business and we bought ours new last season (it's amazing).  We did put spacers in the front for easier turning (they had a pair on the shelf, 4").  They custom make the weeders for different tractors.
We didn't need the block spacer in the middle for it, but it does make easier to step on the clutch when it's up and it raises a little higher.  We did need the block spacer for a tine weeder.  I borrowed the idea from another farmer in the county, his I think is 4" and ours is 7"
It definitely easier to work with having that extra space.
Andrew B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew B Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2017 at 9:37pm
Hello Bill.. I see you mentioning that you remember that widening the G was a problem with broken Axles.  This is important to me as one of my projects this winter before the growing season was to in fact widen up our G about 6 inches total.  When you say 8". Are you referring to each side going out 8 or a total of 8.  (4 a side).  Great that you have dealt with this stuff!!
