190 Allis tires on D17
junkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Topic: 190 Allis tires on D17
    Posted: 01 May 2011 at 5:45pm
I was wanting to through out a question to the more informed (smarter) then I. would the tires and rims (18.4 34) fit on my D17? The thing I was concerned  about was the extra height putting more strain on the drive train. I know where a 190 is with really good back tires even has duals that I think I could buy for less then a new set of 18.4 28s that I currently have right now. any info appreciated
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 5:50pm
how do you plan to attach the wheels? 190 has bar axles, D17 has 8 lug bolt on wheels. Best to just find the right tires, you'll spend more fiddling around than it's worth.
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 6:04pm
that is why I asked. I had no idea whether it would even work. But I think I could buy the 190 for a thousand so figured if I could I might utilize the newer tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 6:53pm
A good deal for a 190 for sure. for rear wheels/tires a 185 or smaller will interchange.
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 7:46pm
i guess the question I should have asked was is there such a thing as a 34" rim that will fit a d17? If so what would I need to look for in order to find them?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 9:12pm
If you're good at welding, it can be done. I have a neighbor that did just what you want. He used the D17 centers and made 4 large "spokes" and welded them to the larger rim. No more power adjust. What he did looks a lot like the rear wheels on a D17 wheatland.
Edited by Brian Jasper co. Ia - 01 May 2011 at 9:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 9:19pm
I always say, give me a cutting torch and a welder and I can make just about anything. A metal lathe comes in handy once in a while.
