38 inch tires on wd45 for pulling |
Post Reply ![]() |
bhalstead ![]() Bronze Level ![]() ![]() Joined: 01 May 2011 Location: Hagerstown,in Points: 21 |
![]() ![]() ![]() ![]() ![]() Posted: 01 May 2011 at 5:15pm |
is there a 8 hole rim that will fit a wd45?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21080 |
Any 38 inch wheel from a Massey or a Ford is 8 bolt and will fit an AC.
thank you for the info
norm[ind] ![]() Orange Level ![]() Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
have sold some wd45 centers and welded them to 38" rim centers [carefully] with no problems
Fields ![]() Orange Level ![]() ![]() Joined: 25 Apr 2011 Location: Reedsburg, Wi Points: 359 |
watch out some ford center hole is 5.5 inch no the 6 inch Allis is.
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 4993 |
a massey 65 with 38's use the same pressed wheel center as Allis with 38's.
ac_bowsers ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Northern IL Points: 251 |
Local machine shop here can make you adapters, made some for my D17, eliminates welding plate to wheels. he has saved the pattern in his machine. pm me if interested
Pine Stock Farm "Home of the ALLIS" 35-WC-36-U-37-UC-47-C-49-G-57-D17-58-D17puller-63-D21-71-210puller-79-7045-83-8070-AA9675-BigTen-B10-310-1300fieldcult-snapcoupler imp.-longhopper blower,signs,etc.
what do you mean by adapters
ky wonder ![]() Orange Level ![]() Joined: 13 Apr 2011 Location: horse cave, ky Points: 647 |
i have a set of 38' ford 8 bolts for a dual set up with decent rubber on them with the heavy ford dual adapters
i like old tractors of all colors
TedBuiskerN.IL. ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
There are actually 8 bolt to 9 bolt adapters in the WD45 parts book, but I doubt if there are any available.
Post Reply ![]() |
