D17 wheel weight question
vyvyjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vyvyjim Quote  Post ReplyReply Direct Link To This Post Topic: D17 wheel weight question
    Posted: 28 Apr 2011 at 8:24pm
I've got a chance to buy four rear wheel weights off of a WD45.
1.  Will they fit on my Series IV D17?
2.  What are they worth?
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 8:46pm
as to what they're worth, 100 bucks a set is the average I would think.   Less then that is a deal.   I know they're not the correct weights for your tractor, but they may bolt on.   They weigh about 135 lbs each.   I have never tried to put any of mine on my series 4.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 9:29pm
I keep hearing guys say they go for a buck a pound.
They should bolt right on to your series IV D-17.
The rims are different on the series IV but I believe the wheel center
is the same on all the D-17s.  I see lots of the WD-45 style weights on
D-17s. As a matter of fact I've seen very few of the "pie" weights on the D-17s altho that is the style shown in the parts book.
Larry Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 10:50pm
I have the 45 wts on a S III that has the same center and rim as the S IV. The weights will bolt right on just fine. The problem is they cover the nut for the power shift rim. If you don't change width - no problem. I needed to change mine a lot due to trailer width. I drilled new holes in the center to rotate the weight about a quarter turn so the notch in the weights lines up with the the rim adjustments.
I used to be young and stupid, now I am not young anymore.
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2011 at 9:54am
I have put them on my D17 IV.  They will fit fine.  I have seen them sold anywhere from $100 to $200 for a set.  I got lucky and bought my set for around $90 or so, I think.  Saw a single one go for $60 last weekend.
