Winches
old220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote old220 Quote  Post ReplyReply Direct Link To This Post Topic: Winches
    Posted: 28 Apr 2011 at 2:44pm
I need to retrieve  dead hd7  loader asume it will roll. how big of a winch will I need. Will a 15000lb work with a snatch;  block I have a 50000 lb pintal hitch trailer. any other ideas on how to get home.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 2:53pm
 As long as it will roll it won't take much to winch it on a trailer. 15K w/snatch block would be plenty.....I doubt you would need the snatch block. If the tracks won'r roll all bets are off
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 3:06pm
I loaded a HD5 onto my trailer using 3 , 1 Ton come alongs . 2 were  mine and the guy I bought it from has a Harbor Freight unit, his ended up breaking and had to finish loading with my to CM pullers ..
 If it rolls no problem, another one i bought ended up loading into rubbish box (rolloff box) using the cable from truck to pull it into box. Unloading was easy , open door and let it roll out as box was tipped once back of box was on the ground.
Faith isn't a jump in the dark. It is a walk in the light. Faith is not guessing; it is knowing something.
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
beeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote beeman Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 10:22pm
I bought a 1942 Cat R4 that had sat for years and  its tracks were really rusty and stiff.   I used a mix of diesel fuel and old engine oil to spray the links and most all the under carriage. Used a cheap  1 gal .  garden sprayer.  Sure helped it move  easier.
1949 B   3930 Ford- Have owned other Orange ,green,red,yellow,dark green tractors and equipment.
