WD/WD45 connecting rods
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Topic: WD/WD45 connecting rods
    Posted: 28 Apr 2011 at 10:37am
Are the lengths of connecting rods supposed to be different between the WD and the WD 45? I have a spare set of WD rods that will have a smaller crank bore for use with shims, and I have a bent rod in my 45-most likely from unsticking rusty cylinders, so I am wondering if there is a way to use what I have to get this thing going again. I looked at the other rods in the 45 and they all have the U3988 number forged into the beam, and my spare WD rods have the same number, which leads me to believe someone used the wrong rods with a 45 crank.
Can anyone enlighten me on this? I don't know if I can accurately measure the rod length on the bent rod to compare with others, and I haven't pulled the other three pistons yet to measure them.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 10:41am
the rods are the same length 7.5 inches
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 10:42am
They are the same length.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 10:44am
From all I've been able to find out, the rod (casting #U-3988) was used on all the 201/226 engines from the WC to the 170. I know for a fact that rods for a WD and a WD-45 are the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 10:44am
Thank you. I suppose the pin placement in the piston makes up any differences. How wrong would it be to shim up one of my spare rods? Would the shims make enough weight difference to matter in one of these slow running engines?
I know I could have one machined to fit like the later style, but I don't have that kind of time. This thing is gonna be in the way if we ever get to plant corn. I am hoping that happens sometime in the near future.
Edited by redline - 28 Apr 2011 at 10:46am
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 10:48am
Have 2 NOS 226 rods. # 232569 if you need one. They were original Pt # 280006, re-labeled to 232569. Complete w/bolts,bearing's. On the rod itself say's; Atlas26/U-3988. Parts book only show's one number for WD/WD45G/W226 engine.
Edited by Chris/CT - 28 Apr 2011 at 10:49am
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 11:04am
I would plastigauge it and try it.  Might not need any shims, my WD didn't.  If it did I wouldn't worry at 1400 RPM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 11:38am
I think that might be what I try. I suppose I could put all 4 rods in it and shim them all, but I am gonna consider this option first. I see the listing shows part number 204720 for the shims.
Thanks for the help everyone. I wish time and distance weren't against me on the NOS rod offer. That would really be the best option.
Edited by redline - 28 Apr 2011 at 11:40am
Larry B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry B Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 12:29pm
i have a set from a wd45 if you need one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 6:10pm
I was always taught WC's and WD's always had shims on the rod caps and main caps. WD45's had main cap shims and no rod cap shims. D-17's had no shims on mains or rods.
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2011 at 12:35pm
I got the shims through AGCO and shimmed the rod I had. The clearance worked out good, but someday there will be somebody else open that engine up and they will be bewildered. I don't have any concern about balance, I am sure they varied by at least that much on a regular basis anyway. It looks like this 45 will be put on the back burner for a little while. I am hoping to do a little field work in the next few days. Earning a living seems to take priority-doggone it.
Thank you for the offers of spare parts, and the advice offered.
This page was generated in 0.056 seconds.
