wd rear end lube
billfosburgh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote billfosburgh Quote  Post ReplyReply Direct Link To This Post Topic: wd rear end lube
    Posted: 27 Apr 2011 at 12:21am
how much fluid & what kind does a wd hold in the rear end & tranny. 80/90?
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2011 at 6:43am
Thats what I used in mine (80/90w), my book says 17 quarts, if a p.t.o. is installed on the transmission add one extra quart. hope this helps    Josh
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2011 at 6:58am
Three drain plugs and two filler plugs.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 9:33am
I got a 5 gallon pail of hy-tran fluid, you'll have a couple extra quarts left over for the hydraulic reservoir too. Put 85W140 in the final drives, really quiets them down. If you have a little more time, remove the battery box and cover over the hand clutch and fill it that way. Its easier to see and pour right out of the pail. Just take the filler plugs out and dump it in until it comes out the filler holes.
Edited by Bill_MN - 28 Apr 2011 at 9:35am
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2011 at 9:47am
As they said, three drains (make sure you drain all three) and two fill plugs for two compartments. The oil has to make it's way past a bearing to get from one side to the other and will seek its own level, the colder it is the longer it takes to level out or you can use both fill plugs.
This page was generated in 0.062 seconds.
