Three point sway control |
Post Reply ![]() |
bwp ![]() Orange Level ![]() ![]() Joined: 02 Oct 2010 Location: Elko, NV Points: 500 |
![]() ![]() ![]() ![]() ![]() Posted: 25 Apr 2011 at 10:31pm |
Hey guys,
I put a 190 three point on my D19 and would like to know what was originally used to control sway. It looks like it may have used blocks as sway control? I think I'm just going to fab up some telescopic sway control arms. Thanks, Brad |
Dans 7080 ![]() Orange Level ![]() Joined: 05 Feb 2010 Points: 1146 |
They used "sway blocks". They could be removed or added depending on the catagory of 3pt you needed.
Thanks Dan
Eldon (WA) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
They should look like this. The bottom ones are for cat II, the small ones stored above are for Cat I implements.
ALLIS EXPRESS!
This year: |
Ok so for curiousity, does anybody have a set of cat 1 and cat 2 sway blocks off a 190 they would be willing to part with? Thanks.
Brad |
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 32518 |
I am still on the scrounge for a set of Cat 1 blocks. Cat 2 blocks are still dealer and aftermarket available but the bolts are not.
Dave (NE) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Eagle Nebraska Points: 2152 |
I'd like to find some of the cat I ones also, so if anyone has any extra, let me know. Dave
Skyhighballoon(MO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Good luck finding sets of the Category 1 sway blocks...very very hard to find. Mike
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
Here is a better pic of the Cat I blocks. Mine are under lock and key!
ALLIS EXPRESS!
This year: |
JoeO(CMO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Cent Missouri Points: 2694 |
I have a pair, not for sale. As Mike mentioned, they are RARE. I think they were optional.
Ok...I guess if someone on here does have an extra pair they want to sell, I will be the guy that started an all out bidding war. I called probably the only all AC salvage yard here in CA, and was told they have a couple of 190s out in back, but the mechanic was too busy to walk out in the yard and look. I was also told I couldn't come and look for myself. Kind of irritating since it's not too far a drive. I kind of thought these sway blocks would be hard to get ahold of. If so, I'll just make some pretty solid adjustable sway arms. Thanks for all the responses.
Brad |
rhartwick ![]() Bronze Level ![]() Joined: 10 Apr 2011 Location: NY Points: 41 |
Hey Eldon,
Any chance you could post the thickness of the Cat 1 blocks? It seems like a regular hunk of steel cut to roughly the dimensions should work. |
Chris/CT ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Niantic, Ct Points: 1939 |
I had set lazer cut from steel chunks by my welding guy. My T+D friend still has them for drilling, been awhile, I better call him.
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Doesn't look like it would be a difficult casting, though it would be handy to cast the square bolt head recess. Carve a pair out of wood at little bigger with some shrink built in and find a cast iron foundry.
Gerald J. |
Post Reply ![]() |
