crank pulley repair
tobiaslong52 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tobiaslong52 Quote  Post ReplyReply Direct Link To This Post Topic: crank pulley repair
    Posted: 25 Apr 2011 at 5:56pm
grooved crank shaft wd front how do i repair?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 9:49pm
Crank shaft or the fron pulley ? if crank look to have it reground undersize if pulley use a speedy sleve to cover worn area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 7:40am
Need more info.  MACK
MilesGray (CO/KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 7:51am
Repair shop wanted 600.00 to repair my B crankshaft, I am getting it back today, unrepaired. I figured if I could buy a refurbished one for 300-375, why spend the money to repair the old one. Repair shop said it was at .009 and needed to be buit up.
I'm not trying to highjack the post, I need to know how to repair mine, too.
Miles
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 10:05pm
Leave the pulley alone... pull out the seal, drive in a new one, and drive it in either shallower, or deeper, so the seal doesn't ride in the groove.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2011 at 3:57pm
belzona supermetal 111
lazyk3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lazyk3 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2017 at 8:04pm
I pulley in front on drive shaft and cannot get off
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2017 at 8:55pm
Lazy K3,
I'm thinking that there is another set screw under the top one in the same hole. Someone will come along eventually and verify that or not but I'm thinking that I've read that on another thread some time back. HTH.
How blessed we are by HIS GRACE!
Post Options Post Options   Thanks (0) Thanks(0)   Quote lazyk3 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2017 at 9:57am
ok i'll check I did not think of that although I've already broke pulley think of getting chisel and break rest way off
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2017 at 12:46pm
A 'hijacked' 6 year old post !!
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote lazyk3 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2017 at 12:34pm
I don't thimk applies here thet shaft is recessed in
tpulley ,it is a double belted pulley  check what another set screw underone I removed
Post Options Post Options   Thanks (0) Thanks(0)   Quote lazyk3 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2017 at 12:36pm
I checked no other set screw and I'm starting to break it off the shaft ,I am totally   stumped by this
Post Options Post Options   Thanks (0) Thanks(0)   Quote lazyk3 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2017 at 2:58pm
i have removed set screw and some said it has a second screw. could not find opening to fit allen or any thing else,   i beat on it ,broke off parts of pulley tried to drill out  set screww cobalt drills don't work. it has about four inch play but will not come of ,about ready to find a tourch
Post Options Post Options   Thanks (0) Thanks(0)   Quote lazyk3 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2017 at 3:01pm
i think your right about second set screw tried drilling it out with cobalt drill and they don't work one hard screw,am at wits in
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2017 at 4:45pm
Don't use torch.
Use a 4 1/2" disc grinder with a thin cutting blade.
Grind down 'close' to crankshaft, do same on opposite side, then split apart using a hammer and chisel.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2017 at 4:55pm
And what model is he even working on???...  is it even an Allis-Chalmers ??
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2017 at 6:32pm
Very good point Dr.
The original Poster from 6 years ago mentioned WD, so I assumed a WD.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote lazyk3 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2017 at 8:31am
I have tried that bought new chisel and tried sawall all didn't work ,I have bought new set of drills and eezzzout new sawall blade, the grinder was hard to get next to and didn't make much of a dents ,but thanks any I amm back at this morning and have for local advice of someone that works on heavy equipment
