Drawbar, 180
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Drawbar, 180
    Posted: 25 Apr 2011 at 8:15pm
Anyone here weld up and re-mill their drawbar at the outer pin hole?  I am about to go this route and wondered if anyone had done it with poor results as in losing the temper in the bar?  I am using the drawbar more often than the 3 point on the old 180 and the wear is damaging my pins/hitches on the drawn equipment.
allis restorer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis restorer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 8:18pm
I welded one up 2 weeks ago and had it all milled, and turned out nice, a little bit of time involed, just weld it and let it cool on its own. I just used .035 Hard wire and keep filling it in. good luck Steve
Go orange or Go home!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 5:40am
Thanks, I am going after mine as soon as I can get to it.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 8:30am
What is the correct diameter of the pin hole?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 8:50am
Can  you drill it out and weld a bushing in of the correct hole size then cut/mill off the excess bushing length on both sides do the drawbar is flat/smooth again?  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 11:05am
I don't know what the original was as someone prior to me gas-axed the hole bigger (1 1/4" x 1 3/8") so I am going to weld it more closed, possibly weld overlay the tongue region as it too is worn severely and then re-mill it to correct thickness and drill/mill the draw pin hole to 1 1/16" so the pin will give some in maneuvering.  I will have to get a photo of before and during then after as I finish up.
kev/ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kev/ont Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 11:12am
if you put a piece of brass in the hole first you can weld it up without milling it afterwards. you'll be left with a round hole the size of the brass.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2011 at 11:48am
This is where I started and ended, I have a little PO2 drying on it to put it back up:
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2011 at 1:20pm
Looks good as new.  Hopefully the welding didn't mess up any heat treating, if those drawbars are even heat treated metal.
Hurst
1979 Allis Chalmers 7000
5800 Hours
