WD or WD45?
deereequipment1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Topic: WD or WD45?
    Posted: 25 Apr 2011 at 2:00pm
hey there.
I had purchased a WD45 to pull antique tractor pulls.
I went to practice, and it had a little problem, so I didn't pull.
While there, a few other allis guys were looking my tractor over.
they said I have a WD engine.
Well, it appears that I might have the WD45 engine, but just the WD head on it.
My serial number says WD45.
Curved shifter says, most likely WD45.
The guys told me that since I didn't have the long plate on the Right side of the engine, that this engine was a 201, therefore a WD engine. The head, definitely is not the tall one.
then, i've been doing alot of reading, and I've read that the WD has the plate on the engine, not the WD45. So I looked at my junked WD and my junked (headless) WD45.
Our old WD has that plate. Our WD45 does not have that plate.
My WD45 that I plan to pull with, does not have that long plate, it just has the shorter head on it.
Does this sound right? It appears that I have a WD45 block, but a WD head on it?
Below where the oil filter is, there is a small spot that has a 2"-3" plate, with 2 bolts holding it on. Its like a little red cover, where the 2 junked tractors just have a formed area in the block, but no holes or bolt holes. Any ideas what this spot is for (see photo)?
Thanks.
Edited by deereequipment1 - 25 Apr 2011 at 2:13pm
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 2:21pm
That plate for a fuel pump?  Does the engine have a full-flow oil filter?  You might have a 226 block out of a E-gleaner.
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 3:56pm
it doesn't have a spin on filter, it has a housing with a cap, and a filter element goes in it.
Does that sound like a Gleaner engine?
Did Gleaner engines have different heads on them originally?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 4:07pm
The engine with a plate on the side is a 201 WC-WD engine. The 45 engine did NOT have a plate. Why not tell us what the engine number (not the tractor number) is and then somebody night be able to tell you what the engine came out of.
 The last WD's produced had the 201 engine(with a plate)with a curved shifter. I don't know when the break for he tall head was but the head differences wouldn't make any difference in power.
 Since your engine has the fuel pump mount, it is not original to a tractor of that vintage. By the way what is the tractor serial number?
Edited by CTuckerNWIL - 25 Apr 2011 at 4:09pm
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 4:11pm
The head could make a difference if it has dished pistons with the short head the compression will be lower.  If I remember right the 201 was a combustion chamber in head design with flat top pistons where the 226 was comustion chamber in piston design with a flat surface on the head.  So if some body put a 201 head on a 226 it would lower the compression.
Edited by Denis in MI - 25 Apr 2011 at 4:12pm
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 4:16pm
I didn't know the engine had any numbers on it. The guy before me painted it with a brush, so I'll have to go over it in detail. Where would the s/n be on the engine?
The tractor serial number is 207-something. I only remember the first 3 numbers off hand.
I knew the 45 block had longer stroke, and different piston design, which makes me wonder if the 45 block would run ok with the WD head. That is also why I am still not sure what I have.
I'll try to find some engine numbers.
thanks everyone!
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 4:19pm
So, if I understand you correctly, a 226 tall head on a 201 will increase compression? That is the combination on my WD, I replaced oversize pistons and sleeves with standard bore (because that is what I had) and used a D17 head, so I might have comparable performance to the oversize anyway? Hmmmm. Sometimes dumb luck is as good as good planning!
Edited by redline - 25 Apr 2011 at 4:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 4:23pm
on my block, on the right side behind the oil filter, is 100-174.
On the left side, at a angle, is L3.
Do either of these numbers tell anything?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 4:27pm
Block serial number should be on the carb (left) side toward the rear.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 4:48pm
OK, I have no markings behind the carb area.
Here is the RS of my engine.
Here is the LS.
Please disregard the special paint schemes the guy before me did.
So I definitely have no side plate.
I definitely don't have the taller head.
This engine also has the 2 port manifold, with no built in thermostat housing (therefore, no thermostat).
I can't find any kind of a serial number, and definitely no stamped numbers behind the carb's air inlet like on Mike's picture.
Any other guesses???
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 4:59pm
There is no combustion chamber in either head, they are both flat.
Edited by CTuckerNWIL - 25 Apr 2011 at 5:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 5:04pm
Look on the rear flange on the left side, in fact look all the way across the rear flange. You might have a LeRoi block. I have seen a block like yours with a fuel pump and it said LeRoi on the rear flange.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 5:08pm
It doesn't mater what head you have as far as compression ratios. They are both flat on the block side.
Edited by CTuckerNWIL - 25 Apr 2011 at 5:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 5:12pm
Sorry CTuckerNWIL.I have looked the block over and over, and can't find anything saying "LeRoi", but
I don't understand what you are talking about as a "flange".
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 5:15pm
Where it bolts to the clutch housing is referred to to as the rear flange.
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 5:59pm
I thought that might be it, but there's nothing in that, so then I wasn't sure.
things that make me go Hmmm!
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 6:01pm
This might help. On the left side of the engine right behind the carb is the engine ser #
like below. The top pic is a 226 out of a WD45 and the next pic is a 201 out of a WD. Don
Edited by Don(MO) - 25 Apr 2011 at 6:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 6:11pm
Thanks Don (MO).
Mine has nothing there (figures!).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 6:36pm
Thats not the first one of them with out no's. with a fuel pump hole that is covered with a plate and no ser # this is not a Wd45 engine that came in the tractor new.
One more thing you can look at is the water pump mouting bolts are they 3/8" with a 9/16" head or 7/16" with a 5/8" head on them? Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 6:39pm
The only other place Allis put  serial number on this vintage was the early WC's without the starter. They were stamped on a pad on the back center of the block which would be covered kinda, by the starter. If your block doesn't have the push rod plate on the right side, it wouldn't be stamped there anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 6:42pm
The waterpump bolts are 3/8" with 9/16" head.
What does that tell me?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 6:44pm
Use a 9/16 wrench to remove the bolts and a 3/8 tap to chase the threads. :) That was just too easy. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 7:03pm
too easy for you!
I'm the one here trying to figure out what mess I've got myself into.
I want as much power as possible, but not sure if I should locate a WD45 head and put on here or not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 7:05pm
Charle I'm thinking the same thang as you he's got a Lerow engine and the name as been removed to hid it. The governor/ distributor drive looks wrong,
like it's out of a M Farmall.
The 3/8" or 7/16" polts in the water pump thing was thinking it might be a "E" Gleaner engine but if it's got 3/8" bolts in the pump it's not a "E" engine.
One more place to look is on the right side of the block right below the gover drive see if there's three no's that are razed up like a 386 on there. Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 7:11pm
I'll look for those markings Don.
The distributor is supposedly off something Farmall. Super B or something the guy said.So I know that isn't Allis original. I think the guy did it when he switched it over to 12 volt.
this Lerow engine, is it a bad engine?
What was it used in, tractors, industrials, ????
thank you for your comments Don!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 7:15pm
Sorry, I didn't see Don's post. I have no idea what the bolt size would indicate.
 A different head won't get you anything as far as power unless you don't have good air flow and buy some ported and polished thing. If you want to compete with the big boys, cubic inches is the only real answer. You can spend a lot of money getting up around 400 cubic inches out of that engine and may still not compete.
 I know a couple guys running stock RPM on MM UB's that dyno 150HP. The block looks all original from the outside but you won't believe the work that has been done on the inside. They are both more than double the cubic inches of the original block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 7:18pm
It looked like a IHC Farmall setup and thats OK, the Leroy engine is a good deal too, they are just a different engine than the WD45 used. Im not up on them. Let us know.
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 7:20pm
There aren't any raised numbers anywhere around the governor.
One other thing, there is a large, about 1/2" set screw type of plug, uses an allen wrench, at the location to the rear of the carb, where these other photos show the serial number.
I guess it must have something to do with the original fuel pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 7:21pm
I can see down between the box that holds the headlights, and the back of the block, and nothing stamped there either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 8:17pm
OK Guys, I think I figured it out.
Thank you for the tip about Leroi. I hadn't a clue.
I searched and found an old post here about Leroi's, and someone had a photo.
Its the same engine I have.
http://www.allischalmers.com/new/forum/forum_posts.asp?TID=24948&title=d201-leroi-progress
It has the same oil filter houseing, the same little plate, same set up for distributor.
The same non-thermostat water manifold.
This is a Leroi D201 engine.
At least, now I know.
