D 15 II
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Topic: D 15 II
    Posted: 24 Apr 2011 at 9:58am
Finally got a chance to do some touch up maintenance on my recently acquired D 15. Was the series II originally 12 volt positive ground? The new ammeter I installed is not showing that the generator is charging but the battery seems to be doing okay. I will get my meter out and do some trouble shooting when I get time. The wiring behind the instrument panel is a mess. I ordered a new temp guage (ouch!) and new oil pressure guage.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 10:03am
My D15SII is 12V pos ground.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 10:07am
I think all 15s were 12 volt positive ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 12:19pm
Thanks for the replies. I thought that was the original set up. This is the first D series I have worked with. I do have a service manual ordered so that should help educate me somewhat. This tractor has been repainted but definitely not restored. The spark plug wires look like a bird nest over the distributor, probably close to 3 feet in length on each one. They are being replaced.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 8:26pm
all D 15 nd late D 14 werew 12 volt. Temp gaige can be had for $49.00 with Allios Chalmers on it or non AC for $ 20.00. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 8:29pm
Steve NJ has the best wire set, bar none. I have several sets from him pleased with each one. HTH Tracy Martin
