Battery for a 918H
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: Battery for a 918H
    Posted: 24 Apr 2011 at 6:15am
Just wondering who make an OEM battery for the 918H?  I can't seem to find a round, top post battery that will fit in the original spot.  I guess I can't complain, the original has lasted for 13 years!  I hate to go to a smaller one, and have to change the cables and/or the ends.  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 7:19am
Hay Kevin.If it looks like a 'regular' lawn tractor battery but with top posts I have one sitting here,don't ask why.I think it came from a Toro machine($$$), maybe your nearby Walmart or crappytire.I know Walmart is $10 cheaper( $24) than CrappyTire($34) for the SAME battery ! Also CrappyTire do have long,narrow,tall car batteries(fits Honda),top posts good for forklifts($70).Shoot ,getting old sucks, that battery I mentioned was from CTC for a forklift NOT a Toro...sigh...old age...what else to look forward to ???
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 7:31am
Kevin You can get a battery at NAPA the group size for a 900 series tractor is 22NF, its not cheap, but should last another dozen years. Cal in Ct.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 7:40am
Thanks, guys!
skip(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skip(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 10:25pm
i bought the highest cca rated lawn battery from my local interstate battery guy. it fits w/ plenty of room, but it does have the lawn type terminals on it. plenty of power to get the mower turning though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 10:59pm
Skip - my 716H from Don(MO) uses lawmower type connections and not the regular round post automotive type so I just did the same as you did, bought the highest CCA one they sold and stuck and stuck a short block of 2x4 in next to to it to snug it up since the slot was longer.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 11:10pm
I also did the same on my 716H.  Must be the new trend.  LOL
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2011 at 11:19pm
All the auto style batts Iv'e had in my 7016 Simplicty's had caps and oozed wet all the time making a mess of everything.One is starter/generator,other is ring gear starter W/stator charging.I don't believe it is an overcharge thing.Anyway, I found a sealed top little 300 cca like the B1 use(lawnmower terminals) and made a hold down bracket and changed cables and it's GREAT!!! No mess and spins a 16hp Briggs. I think the original is a match for some Ford  battery.
Bill(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 6:23am
One size that fits is a Group 51. Expensive. Found one at Sams for $58 after I had already bought one from local garge for $72. I Was told this same battery is used in some smaller Jap cars...Mazda and Honda and even some older Fords.
