"G" Cultivator Parts Need
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Topic: "G" Cultivator Parts Need
    Posted: 23 Apr 2011 at 10:04am
 I'm in need of 3 different parts for the rear furrowing bar. All the parts I need are colored in the picture. I need 2 of item #13 part #308217 shank clamp, 2 of item #12 part #307933 shank clamp plate & 4 item #14 part #316847.
 Thanks for your help.
Thanks & God Bless
Dennis
Warren(Oh) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2011 at 10:49am
I could use those pieces, too but I plan to make a clamp that should work as these do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2011 at 11:16am
The plate should be easy to make if you have the dimensions of the clamp. The u bolts should also be available from Fastenal or somebody if you know dimensions. If a guy had one old clamp, and access to a decent break, the clamp wouldn't be hard.
 I'm not too helpful this morning Dennis.
singingpig View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote singingpig Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2011 at 2:08pm
Hard to find pieces...I just had a piece of 2inch square tubing welded on so I can buy off the shelf tools.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2011 at 6:14pm
I should have them i will take a look and see what all is there Matt
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 10:45am
Those formed/stamped pieces are made from 1/4" thick steel. I have an 8' sheet metal break but it is only rated for 18 gauge steel.
One might better get some 1/4" thick angle iron and weld those brackets up. I have a couple of them, not for sale, I can measure them if someone wants to try to make one. Or I can try making a couple for you.
Dusty
Edited by Dusty MI - 25 Apr 2011 at 10:46am
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2011 at 7:12pm
I have several of the unit brackets you need.Also have several of the single U bolts and brackets that bolts  thru the frame on a G Cult. Will sell them. 785-353-2392
