D17 power director hanging up
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Topic: D17 power director hanging up
    Posted: 22 Apr 2011 at 3:57pm
My 17 is hanging up occasionally when I try to pull it into the low side. The hogh side work fine. If you go to high a couple of times it will go into low. it doesn't slip when it is in low. I have the side cover off and there is nothing obviously wrong. Has anyone had this problem?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 6:54pm
My guess would be the neutral catch mechanism is getting caught somehow when pulling the lever back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 9:02pm
I had the side cover off and it would still catch. It has to be in the low side clutch pack. It worked fine and started doing it when I was rotobaling last year. I looked for loose pins but didn't find one. Is there a snap ring holding the drive hubs that could have broken?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 9:33pm
Could be a broken plate stacking onto another plate.   MACK
