Wrasslin' with tires
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Topic: Wrasslin' with tires
    Posted: 22 Apr 2011 at 10:32am
  I was going to mount the 16.9X28's on these this weekend.  Wheels are 133 lbs. each , tires are 156 lbs. I'd like to think I could do it, but maybe I'll load em up and have a pro do it.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 10:41am
Thats the way to handle that stuff for sure.
I lost a carrier bearing on one of my Oliver 1850's when i was farming and used one just about like that to remove and put back a loaded 18.4 34 loaded tire, rim and center. I got it done but it caused me to buy a heaver engine lift. The lighter one has sway back feet now. Like the lumber carts. It has six wheels but if you hold it just right you can move it around in just two. (:^D
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 1:29pm
If you let the pros do it, it might protect your paint job a bit.   The couple that I have mounted and dismounted, it does seem the easiest to have the rim mounted onto the tractor for stability and then work the tire on.   I have found that the bigger the tires, the easier they are to get on and off.   If it were me, I would put some masking tape on them and lube the beads really good and give her a whirl.   The last time I took them in, they got me 75 bucks to dismount and mount them.    I like keeping those greens in my pocket for other AC stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 1:36pm
Gary, are you building a puller. I wouldn't have thought F&H made a 15 inch wide rim but it looks like those are wide. I did my 14.9-24's for Lena on the floor of the garage. Next time, I'll try working with them bolted to the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 3:42pm
They are only 12"wide, I intended them for 14.9 but I only have 16.9's.  My 16.9s were on 12" spinouts at one time , then 15s,  !5's are ideal, but these will work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 5:40pm
I mounted the 16.9's on my D17 at home with a couple crow bars. Some liquid dish soap for lube and it really wasn't all that hard. Didn't skin up the wheel either. I'm just an average strength/size guy. $25 ea to dismount the old tires was $$ well spent. One tube didn't survive due to the rust on the wheel.
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 6:03pm
If the tires are new its a pieeeeeeece of cake. Shouldn't even require tools. If they are older and a little age hardened then it might take some steel persuasion but still very doable for anyone.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 9:26pm
I always install tires with a hammer instead of irons. Fewer tube pinches. I have done dozens that way. Bob
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 10:31pm
Just lay the rim on the floor and let gravity help you out. Putting tires on is easy....getting the old ones off is work.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2011 at 7:43pm
 Well , they are mounted. Only took a  couple hours, a few beers.  Luckily a buddy stopped by and got sucked into the job. Should look O.K. on the WC-C11 project.
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2011 at 7:56pm
Very, very nice. I saved your entire string of beginning to end rim modification pics, and that is beautiful workmanship.
Edited by GBACBFan - 23 Apr 2011 at 7:57pm
are genuine." - Mark Twain
This page was generated in 0.087 seconds.
