pedal tractors
ac418 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac418 Quote  Post ReplyReply Direct Link To This Post Topic: pedal tractors
    Posted: 21 Apr 2011 at 6:42pm
Any one know the scale of a pedal tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 8:59pm
I would take a wild guess and say about 1/4???
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 9:28pm
about 1/4 is as close as you'll get. I just went out and mesured A WD45 Pedal tractor has a 28" wheel base and A full size has a 96" wheel base. the variable here is all pedal tractors that I've seen have the same wheel base regaurdless of what tractor they represent. this is because they all need to fall into the same size range for a kid to ride. When looking at the store a CA, WD, 190, 8050. pedal tractor they were all the same size use the same wheels, pedals, steering,and  axles. When I converted My Sons WD$45 to a Wide front I used the front axle part # for a 8050. its the same part # for a 9N. just a differant color.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac418 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 10:00pm
Thanks for the info on the pedal tractor.  I will put this info to good use.
This page was generated in 0.077 seconds.
