New Film Reel:6060 & 6080
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Topic: New Film Reel:6060 & 6080
    Posted: 21 Apr 2011 at 9:20am
[TUBE]S53QuhtXMr0[/TUBE]
"Better By Design"
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 9:55am
Now I got to have one!
Wink
I am a Russian Bot
nsula_country View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsula_country Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 9:56am
You should not have posted that. Now I want a 6060 FWA! Nice video.
Thanks,
CT
smokey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smokey Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 10:29am
Thanks for shareing, I can remember that Dad tried a 6060 out back in 1980 or 81 I think, it had FWA and it was impressive, we had a 175 that he pulled 4-16" with and it was in the dry time of the year, we had some wheat stubble that he had been plowing and the ditch bank was so hard that the plows hardly would go in the ground, and when they did the 175 would just sit there and spin.
The dealer brought the 6060 out and he hooked it on the plow and went to ditch bank and put them in and it did the same thing spun, then the dealer put it in FWD and WOW impressive no problem, Dad just couldn't see $22,000 then he said, when he bought the 175 in 1974 for like $6500 new, just didn't add up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 1:34pm
Glad it's a hit! :D
"Better By Design"
Michael (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 2:57pm
It certainly is interesting to watch, especially seeing the charts.  We have a used 6080 fwa now since I started running the farm.  When my unlce was running it before my birth he had both a JD 2440 and JD 2940 fwa.  This was mainly because the AC dealer had closed and they wanted a tractor with a local dealer.  After I was old enough to drive they were upgraded to the equivilant replacments of a 2550 and 2950 fwa.  Having driven the 2950 a lot I can definately tell you the 6080 uses less fuel as the graph shows.  Of course the 2940/2950 used a 6 cylinder engine to make the same power as a 6080.   Also, I swear the 2550 uses more fuel cutting hay than the larger 185.  Mike
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 3:37pm
Good Video.
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 4:19pm
Great - thanks for sharing. Sure would like to have a 6080 in my barn.
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 7:32pm
Really nice tractor!
I'm sure they were ahead of the competition back then but I'm also sure they caught up by now. Wonder what they would have now if they were still in business? Probably China built like everything else sad...sad.
AC190XTrescuer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC190XTrescuer Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 8:13pm
love the video wondering if a 6060 tractor was better out of them both. when my dad farmed backbefore i was born he traded the 3020 deere for a 6080 brand new he said he didnt like it and said the 3020 was much better. but i heard that a 6060 is better.
What you cant get done today you can always do tomarrow, And if there is no tomarrow it was a waste of time today
wheatbreeder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 8:36pm
he traded 3020 for the 6060 says allot
Farm stuff 8050,6690,175,F2,5050,WD
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 9:37pm
Nice video.  I would have to say that the 6080 is the better tractor.  6060 Only had an 8 speed that was only partially synchronized.  6080 Had a fully synchronized 12 speed along with larger tires.  Due to poor sales, 6060 production ended in 1983 and replaced with the 6070.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 5:42am
I know a guy who had over 7000 hrs on his 6080 FWA 10 years ago and he used for everything including the heavy tillage as it was his big tractor. He delivered oxygen and acetylene to the shop every week. Now he has a couple bigger 8000 series but still uses the 6080 as far as I know. He loved that tractor the way he talked about it.
Wink
I am a Russian Bot
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 6:05am
They are very nice tractors and a great video too. A guy came in the shop where I work last year to get some filters for a 6070 that the farmer he works for has and he said he figured out why Allis went out of business. I said OK, why. He said they made the tractors so good you couldn't wear them out.JP
Eddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 7:47am
The 6060 is a great tractor. Nimble and powerful.
Allis Chalmers 6060
10' Howse Rotary Cutter
5' Tiller
5' Box Blade
4' Aerator
Ferris Zero Turn Mower W/10' fold up sprayer
John Deere 455 Lawn Tractor
John Deere 955 w/loader &
60" belly mower
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 8:26am
nice vidio i liked it
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 5:07pm
thanks, i enjoyed that
i like old tractors of all colors
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 5:18pm
Dad sold a few 6060's and alot of 6080's and AC replaced the engines in most of them at least once onder warrenty. The thrust on the transmission put to much preasure on the crank bearings and ruined the block. Then in the end i don't know if AC enginers come with it or Duetz Enginers figured it out but they sent out thrust bearing kits for the front of the crankshaft.
So as long as you keep that thrust bearing greased they will last. I can't help wondering how much of that warrenty expense contributed to the end of AC.
They still realy are a great tractor.
The universal answer to all questions is yes, how much do you want to spend?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 5:21pm
The FWA 6080 will out work a 7000 on less fuel.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 7:31pm
That was an Allis fix for the tractors that were all ready sold. The later ones had the heavier thrust bearing internally I'm pretty sure.
Wink
I am a Russian Bot
This page was generated in 0.095 seconds.
