Disc with round snap coupler eye
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Topic: Disc with round snap coupler eye
    Posted: 20 Apr 2011 at 5:52pm
Bought my neighbor's disc that has a round eye in place of the elongated eye.
Doesn't appear to be an Allis disc, no paint left either.
Tried to fit it into the bell but didn't go as it was too round.
It's about an 8 footer.
Who made this type of disc? Case, maybe?? Thanks for the info. Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 5:54pm
Oh yeah, it appears to be a drag type disc as it doesn't have any lifting arms to go to the lift arms on my 45.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 6:33pm
Jim - I have an 8 foot John Deere drag disc with a round eye.  It's meant to be used with a clevis for hook-up to the draw bar.  Does the hitch have a couple of rods running above it and a lever  you pull up with notches to change the pitch of the gangs?  That's what my JD has.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 7:26pm
Mike, I don't like your danged old Johnnie Deere disc it looks for mud holes. lmao
Harvey/pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harvey/pa Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 8:33pm
 I had a 24 blade McCormack drag disc that had a round eye.
Don, from the pictures that Mike posted I thought it looked like that dang green disc pushed you into the mud hole, of course that was awhile ago & I could be wrong...Harvey
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 1:43am
You know what Harvey, now that you mention it, I did see what looked like faded reddish orange paint on it in one spot right after he got it home for a yard ornnament.
It's not there now tho.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 5:25am
We had a MM disk, it also had the round hole, used with a clevis.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 11:19pm
Mike, There are not any rods to shift the gangs to change the pitch.
There is a notched,half inch flat metal "bar" between the hitch angle irons that fasten to the round eye.
By pulling forward or pushing backward to disengage the notch from "rivet" that holds the two angle iron hitch tongues, lift the bar and slide the gangs back or forward to straighten them out.
If you'll post  pic, I can see how your setup is and maybe fashion one on mine. I'd really love to be able to take this somewhere to use besides just here at my place.
Had about 60 acres of hayfield "given" to me to take care of just to keep it mowed down and do with whatever I wanted to with the hay. Got the WD's, just need the square baler now and the rake and haybine. 7' sickle mower might be a little slow, albeit the WD45 is somewhat fuel efficient mowing with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 11:54pm
Jim - here's a pic of the hitch on my JD disc.  You can see the adjustment linkage on top the drawbar.  You can also put a hydraulic cylinder up there too if you wanted.  It's a beat up disc but it still works.  And as Harvey points out, it works good for helping Don find the mudholes, lol!  Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2011 at 12:05am
Thanks Mike.
Mine is not even close to looking like this - frame wise.
Your's makes my frame look anemic.
Guess I had better take a pic or two and learn to post.
Busy weekend with camera work at church and possible rain all weekend long with the overcast sky.
We'll see how bright it is on Saturday to get a good pic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2011 at 12:25am
BTW, what size of disc blade does your disc take?
I ordered 4 16 inchers today from Agri Supply.com  Thank You Dans 7080!
They were surprised that I heard about them from this forum as the lady that I talked to hadn't heard about this forum.
Told them to tune in here and let it be known here what they do!!
se iowa picker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote se iowa picker Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2011 at 8:55pm
Sounds like an international 9b. Not a bad disk, I saved one from the the fence row on the neighbors place before the Cat got to it when they were building a pond.
