Want your opinion!
Phil (WY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil (WY) Quote  Post ReplyReply Direct Link To This Post Topic: Want your opinion!
    Posted: 19 Apr 2011 at 12:58pm
I have a Wd45 with charlynn ps and a wide front (3 bolt), and 2 WDs with nf.  Would you take the wf and swap with a nf to make the wd easier to steer or not?  Opinions are like elbows, everyone has a couple and I would like to know yours.  Btw, I just found another WD close by for $700 and runs good with brand new power shift rims.  Thanks, Phil
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 1:08pm
I don't really know on the steering situation, but I'd jump right on a good running $700 WD anyday.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 1:53pm
Just going through the steering, cleaning and greasing with replacement of needed bearings will make it steer fine unless your using for a loader tractor.
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 2:21pm
In my opinion a wide front tractor with no PS steers easier than a tricycle type tractor with no PS.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 3:49pm
The wide front is safer on hills or when using a loader.
Mark
GTH-L Simplicity
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2011 at 6:45pm
We have WD 45s with the nf and wf, and you can blow on the steering wheels and they turn, best that I have ever used !!!
