Air Filter /Carb ??
Sitesstables View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sitesstables Quote  Post ReplyReply Direct Link To This Post Topic: Air Filter /Carb ??
    Posted: 19 Apr 2011 at 5:27am
Ok so I have had to run my d17 with the choke on since it had no air filter or filter canister caver and was sucking huge amounts of air, My filter will be in today and I have made a new canister cap.. So my question is.. should this fix the issue as to having to run it with that choke open? and would it be a good Idea to clean the carb also? or am I wrong and this was never the issue and there is something else causing me to have to run the choke open?
1965 D17 Series IV
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 5:38am
It should run just fine without the filter. Don`t run without because of getting dirt in the motor. Need to soak the carb and rebuild.
"Burgie"
