D17 vs IH 460
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: D17 vs IH 460
    Posted: 18 Apr 2011 at 7:16pm
How do these two tractors from the same time frame compare?
560 vs D19?
Charlie
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 9:18pm
both were thirsty if on gas
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 9:36pm
Both 6 cyl
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 9:42pm
If you're going downhill with a TA, and you go from high to low (TA), you risk damaging the TA... or at least, the last time I drove a 560 (and a 656) the owner was really, really, really explicit about that.
If you go downhill with a D17 and shove it into low... it goes into low.
If you pull the 560 between low and high, it will either go to low, high, or kinda burn up in between.
If you pull the D17 between low and high, it'll be in neutral.
560 had a little more power at the PTO, ran taller tires, so a little more available tractive effort per pound of ballast.  I don't know whether the early 560's had low-pressure hydraulics or a 3-point, but the later ones (as did the Series IV) did have provision for both.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 9:52pm
Neighbors 560's had 2-point hitch.Made hitching the plow simple.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 10:13pm
D19TD??....no problem!
ALLIS EXPRESS!
This year:
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 5:45am
the 460/560 farmall suffered from to much enjine for the drive train, they basically built the tractors with the same gears and rears that the m's thru 450's had used and that was a little light for the inline 6 cylinder's torque.
i used both back in the 60's/70's, and found the d-19 to be the best set up tractor of the two
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 5:49am
Some confusion here. D17 to 460 AND D19 to 560. There is no way a D19 will be out pulled or out PTOed by a 560. Hydraulics is the weak area on the D series unless they were equipped with the optional front pump. I'd also take a D17 in power over a 460 and I don't like how you get on a 460 or 560 especially when they have fenders but the IH's give a comfortable ride once your on. The IH's also break lots of little parts to do with the fast hitch and the wide front ends were pretty flimsy. The narrow fronts ends weren't all that heavy and it's not that uncommon to see a busted narrow front bolster. The hoods are about as bad to take off as a 190.......or is that the 706 is as bad as a 190........I know the 706 take a while to remove the hood and sheet metal. It seem like everything is in the way if you want to remove the valve cover at least on the 706. Gas tank comes to mind and I think the 560 and 460 are the same that way. The 460 and 560 are both notorious for the hydraulics freezing up in the winter due to moisture and it doesn't seem to matter if they are shedded or not. Also for a 6 cylinder they only have 4 main bearings for the crank and that's for both gas and diesel. They both like to eat axle bearings back in their days of heavy work cause the oil doesn't flow to the outside bearings very well. Today these tractors don't get used heavy like they used to when they were a main work horse so most of these mechanical problems won't be all that noticeable anymore.
Edited by Lonn - 19 Apr 2011 at 5:50am
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 6:51am
Blood line of the IH 460 goes 460-350-300-Super H - H..........Blood line of the IH 560 goes 560-450-400-Super MTA-Super M- M... The 460 line continued on with the 656-666-686 before it died out. The 560 was the end of the road for that chassis. The 706-806-1206 were the replacements.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 7:24am
Yes  I should have separated or better defined to compare the D17 to 460 and D19 to 560.
Around here you find a ton of H/M's, WD's and D15/17 series then it skips to the IH 66 series. Just not that many 460/560 tractor at all.
Charlie
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 10:06am
My dad bought a 560 when I was a senior in high school.  It had a 2 point hitch which worked very well with a semi-mounted plow.  The hitch also had down force so you could put a block under the hitch and raise a wheel off the ground.  It was never a problem to get on the tractor from the rear------there was a certain sequence to where you put your feet getting on.  Once you learned it, it became 2nd nature.
It had good hydraulics including up to 3 remote valves.
There was a recall on the rear end that was performed on the tractor when it was a year or two old.  We never had any drivetrain problems with it (before or after the recall), and it saw a lot of hours (the big tractor on 560 acres).  We had a number of IH's with the TA and the only "problem" any of them had was the a campaign that was done on an early 300 before it had given us any trouble.
If you were going down a hill, you did not want to pull back on the TA.  It was an over-running clutch, and the tractor would go into free-wheel and start accelerating.  The first time I tried that with a 300 pulling a loaded manure spreader, approaching a gate at the bottom of a hill, was exciting!!!
I did drive a D19 once and didn't like sitting down low with my legs wrapped around the transmission.  Figured that would be hot and dusty pulling a tillage implement all day long.
The D19 had another 10-12 hp than the 560.
Edited by 427435 - 19 Apr 2011 at 10:08am
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 10:43am
I have a IH 460 Utility that i bought in 1972, had it overhauled in 74, it has 2 point fast hitch with down pressure . Great for the grading work i used it for , has a henry loader with billet lift arms. srl# places it at 1958 and has the W in srl# for 17 gal hyd pump and a 3 GPM stacked pump for the steering. 5 speed with shuttle instead of TA so good loader tractor. Has tube front axel which in book is called 560 HD with 560 ehd spindles and hubs .
 weak point is the steering box as have went through several gear shafts in box. had the same problem with steering on my IH 300 utility. Tractor is light in rear is biggest problem and have loaded 16.9 X 24 industrial tires and 3 sets of wheel weights on it.
 3 valves on hyd system but can add more is one good thing as the valves are stackable on the body and more valves can be added as needed.
Edited by Coke-in-MN - 19 Apr 2011 at 10:44am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 11:20am
I was thinking that the 560/D19 were within 5HP of each other?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 11:33am
Nebraska tests on a gas 560 was 61.0 PTO hp and a D19 gas was 71.5.
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 12:34pm
D19D is 66 pto hp. Gas was the powerhouse...
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 12:38pm
the brakes on the 460/560 were bad for grabbing.  My uncle that we farmed with had a 560, you always had to remember to hit each brake pedal quickly before using the brakes to stop or they would lock up, epecially at road speed.   We pulled a lot of wagons and hay racks on the road,  they had a nice road gear and the down pressure on the fast hitch was nice too.
amo1977 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amo1977 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 12:53pm
4/560 tractors did have some advantages.  Yes gas, you need to be a member of OPEC.  Diesel, you will run out of fuel because you don't need to check it very often.  Run it for days (hay field work) and next thing you will know is or crap I forgot to check the fuel!
Water in hyd....gear shift is on top of the trans....just like a D-17.  Big problem is the rubber boot on shifter goes bad.  Water follows down shifter into trans.  Also the bolt are recessed that hold trans cover on top of trans.  Put some caulk or something under the bolts to seal em up.  With that said my 806 which has a deck over trans is getting water in somehow.  Have yet to figure that one out.  Older 4&560 or early 656's didn't have enough head bolts either.  Head gaskets are a slight problem.  I have no idea how many hours are on my 656 (460) but I have had it for about 10 years.  First one Ive done.  Tach has rolled over.  If previous owner replaced gasket he didn't do a valve job.  So thin a couple of them were about ready to break off!  They weren't bad tractors.  Every color has good and bad.  I will agree Allis proably has the better hi low.  If you know how to use a T/A they will hold up.  Especially if you use both sides equally, and they say with the mechanical ones to either push in on clutch or pull lever back when shutting it off.
My D-17 is a gas.  So is the WD-45.  Haven't used it enough to check, but it seams like to me it guzzels it about like a 460 or 3010 gasser.   I think its just a gasser thing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote amo1977 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 12:54pm
I also prefer sitting on an IHC vs Allis.  No big deal, just preference I guess
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 3:58pm
I learned that the trick with the disk brakes on these tractors was to keep them adjusted so that just a little pedal travel was needed to engage them.  They were actuated with  2 counter-rotating disks that had groves that tapered to nothing and a ball bearing in each grove.  That forced the disk pads out to the stationary housing surface.  The pads were splined and, if they had to be pushed very far to make contact with the housing, the splines would momentarily lock on the pinion shaft.
I spent a lot of time cultivating with a 300 and wanted the brakes to work without locking when turning at the field ends.  When the brakes would start to lock unexpectedly , I would just adjust the linkage again.
When pulling loaded trailers, did you ever master the trick of shifting from 4th gear direct to 5th gear TA on the roll??
Mark
GTH-L Simplicity
