WD 45 Pan Gasket
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 Pan Gasket
    Posted: 18 Apr 2011 at 10:08am
Can the front engine support be removed without supporting the motor for a short time in order to gain easier access to installing the pan back in place?  Otherwise, is it necessary to place a suppport under the block or front pulley?  Looks like the block is attached to clutch housing by 4 bolts at the most (I don't have the tractor here with me to look at).
Thanks for any advice.
Dennis J OPKs
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 7:24pm
Yes you can remove it and the engine will hang there fine, just don't start her up with the bracket off. If you need some help on getting the pan back on just post about it.
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 8:26pm
Don, thanks for your reply, I think I've read most of the tricks on doing this including curling the end gaskets inside a can to get them curved.  One other question--there seems to be different preferences on sealant, RTV versus others, any thoughts.  Thanks again.
Dennis J
FHOliver View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FHOliver Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2011 at 6:34pm
no silicone permatex #2 non hardening tried and true used at the dealer for yrs.
This page was generated in 0.201 seconds.
