WD front end lube???
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Topic: WD front end lube???
    Posted: 17 Apr 2011 at 8:56pm
What kind of lubercation do you guys use in your WD narrow fronts on the worm gears? Thanks Josh
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 9:31pm
The operators book calls for SAE 140 on narrow front but a wide front calls for SAE 250 all fill just to the top of the worm gear. hope this helps.
Don
