WD Puller
alliswd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alliswd Quote  Post ReplyReply Direct Link To This Post Topic: WD Puller
    Posted: 17 Apr 2011 at 7:16pm
Guys,
Pictures of my 1948 WD with the new pulling tires and wheels.  Went from 14.9-28 (currently on sale on E-Bay!) to 15.5-38 - largest tires allowed in the classes I run.  I know, new tires do not pull the best on all tracks.  I tried to find a used set of 15.5s, but could not.  Cutting them is not allowed.  I'll give them a try this year and see how things turn out.  I have read where you can drag the tractor down the road faster than the tires are turning to wear the lugs down, but I'll give them a try as is first.  Need to mount the fenders also, but they need a LOT of body work.  Needed to redo the wheelie bars, hitch, and fender brackets to get everything back in the right place.  Axle is 6" higher than before.  Goes down the road a lot faster too.
Allis Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 7:22pm
Very nice puller I love the front weight braket cutout. Where in wisconsin are you I live outside Reedsburg. I mostly pull southern wisconsin.
Allis orange blooded by family. Allis Diehard by choice
Post Options Post Options   Thanks (0) Thanks(0)   Quote alliswd Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 7:29pm
I'm in Kiel - about 123 miles ENE of you - according to Google.
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 7:31pm
Purdy!
Greg Kroeker
Deer-Slayer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deer-Slayer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 7:49pm
That is a very well restored tractor. Looks great. I am also from Wi but i am from Soldiers Grove.  not anywere close to Kiel...haha. Im doing the same set up with my WD only running 13.6x38s on mine. just to see how they work out. this year will be a trial and error year with this tractor to see if it is up to par with my last build...
anways just wanted to say how much i like your tractor. Might give me a few ideas for mine down the road when it gets its new paint job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 7:53pm
GREAT job!!  Too bad you aren't closer, I'd come and see it in person!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 7:59pm
Hey that tractor looks familiar!!   Are you coming back down here for the two county pulls?   I am working on a WC for pulling but I don't know if I'll have it done this year.   I might have it up and running but not painted.   Pretty rusty right now, might have to call it "Tetnis shot".   If I remember right, you did pretty good at the Ozaukee County Fair in the 4500 class.   I tried weighting up to the 6000 with my 45d.   I might end up using it again if I dont get the WC done.
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 8:31pm
looks good.  You will be surprised how much better those 15.5's work
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2011 at 8:45pm
clean ride.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 5:55am
any kind of motor work done?
Charlie
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 6:47am
I like that. Where did you get those 38" wheels?
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 7:03am
The weight bracket looks great!!
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 7:47am
here is my puller, with 18.4*38 super all traction firesstones
Post Options Post Options   Thanks (0) Thanks(0)   Quote alliswd Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 8:10pm
d17brown - NICE!
Chuck - Yes, it will be good to get back at things once all of the snow stops falling.
All - Yes, some engine work, but it still runs stock RPMs.  Biggest thing is compression increase with a WD45 crank.  Horsepower was not my problem - traction was.
Post Options Post Options   Thanks (0) Thanks(0)   Quote alliswd Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 8:14pm
jayIN,
Wheels were custom made.  They took a 14" wide rim and welded in the centers at the offset I specified.  Then, powder coated them Silver.  The centers are 1/2" thick steel.  The wheels and tires each weigh 130# more then the original 14.8-28s with spin outs.  I'll have to run one less wheel weight.
