wothington compressor
Neftali View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Neftali Quote  Post ReplyReply Direct Link To This Post Topic: wothington compressor
    Posted: 14 Apr 2011 at 3:20pm
I got mi self a 1974 worthinton compressor 600 cfm 150 psi. need manual or what ever info yuo can provide. it is nor a piston nor screw tipe compressor. The compressing air unit looks like like  a tuvine. it was powered by a 210 hp caterpilar motor that was remooved. nee help to get it working. thanks
ardensmith View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ardensmith Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2011 at 4:01am
PSI is located in Massachusetts not far from the Worthington Holyoke plant where Worthington Holyoke compressors were manufactured between the early 1900s and 1980. PSI has supplied after market replacement Worthington compressor parts for more than 30 years.
We manufacture many of the replacement Worthington valve plates, ring kits, gasket kits, and replacement valve components here at PSI to standards exceeding the OEM. Better than new replacement parts to help your Worthington compressors stay online.
PSI supplier compressor parts for nearly all Worthington compressor types including:
  • Worthington Type C Reciprocating Compressor
  • Worthington Type M Air Compressor
  • Worthington Type M Reciprocating Compressor
  • Worthington Type X Reciprocating Compressor
  • Worthington RS Rotary Vane and Rotary Screw Compressors
  • Wothington Rollair Rotary Screw Compressors
  • Worthington Type R Rotary Vane Compressors
  • Worthington V2A4/SAB High Pressure Reciprocating Compressor
  • Worthington Portables Compressors (160 CFM-1150CFM)
thanks
[url=http://runninggearworld.com]running gear[/url]
Post Options Post Options   Thanks (0) Thanks(0)   Quote Neftali Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 10:39pm
I need to know if I can get a manual on the compressor
This page was generated in 0.168 seconds.
