"WD" Spring tooth field cultiator parts wanted....
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Topic: "WD" Spring tooth field cultiator parts wanted....
    Posted: 13 Apr 2011 at 6:54pm
Anyone know parting out one? I tried my agco dealer....seems these days if you're not buying a new skid-steer from them, they don't have the time to look for the old stuff. Anyway, I'm looking for part #320369...they are the "caps" for the end of the tool bar where the truss rods connect to, and I need 2. My scanner is on the fritz...so I don't have a pic from my parts book. I also need 3 "spring teeth", part number 324409. Any help would be appreciated. Chad
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2011 at 6:59pm
 I have the caps  send me a PM   Matt
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2011 at 8:33pm
Chad, Are those spring "teeth" the double ended points? if so, I have 6 total, all new, 2 look heavier than other 4. I also just threw a dbl layer curved tine in my recycle bin for that unit I think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 7:58am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 8:00am
2 same [design #1], 2 same [design #2],1 original AC?
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 9:05am
Chris, What do you get for them? I'm needing one like you posted on the right side.
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 9:52am
Don, Offered all to Chad, If he does not take them/need the end one you may have it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 11:38am
Chad I'm SORRY; I didn't mean to step on your deal.
Someday I'll learn to read things two or three times before posting. lol
Chris if he leaves some behind I'd like in on one of them.
Don
Steve(SEMN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve(SEMN) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 11:41am
fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve(SEMN) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 11:42am
Fleet farm carries those points and they are very similar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 4:05pm
Thanks for the pic Chris....I actually need the spring that those points bolt to, as I have 3 that are broke off. The termonolgy I used came right from the field cult. parts book, so sorry for the confusion. Don...I understand the PM now, and no offense taken on anything! I'll try to get a pic here soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 4:36pm
OK....got someone smarter than me to help here! This is the pic of the of the "spring tooth, item 1 " that I need 6 of....
And this if the pic of the "cap, item 7 " that I need 2 of....
Thanks in advance for all of the previous comments and help. Chad
Edited by Chad(WI) - 14 Apr 2011 at 6:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 4:46pm
Chad, are those similar to the ones that come on a two row WD cultivator?   I might have a couple extras here.   I will go out and look.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 4:53pm
Chad, the springs that you are looking for, do they have one or two pieces to them.   I have some from a partial set of mounted cultivators, that look just like them, but have two spring pieces that go together to make one spring piece.   I will post a picture.   I have 5 of them, and they aren't anything like any of the other cultivator parts on my other set of field cultivators, so I have no use for them.   I will post a picture of them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 5:41pm
Chad, here is a pic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 5:50pm
That's interesting Chuck....they look correct, but do you think they are just doubled up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 6:23pm
OK Chuck...Did some measuring, and mine are 1/2" thick....Don't think yours will work but thanks for checking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2011 at 9:56pm
I have the spring teeth, a bunch of them.  Just south of Brodhead,WI in IL
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2011 at 1:03pm
Hi: Do not want to get in to some one elses deal. The springs you need are about 48 in around  with out the shovel. They are about 1/2in thick. The cult. springs are about 40 in around. There are two of them one on top of the other. I have all of the above springs. The caps go on a 1 3/4in tool bar. I have them. 785-353-2392
This page was generated in 0.742 seconds.
