WD front wheel bearings
JohnCinMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Topic: WD front wheel bearings
    Posted: 13 Apr 2011 at 1:26pm
The front wheel bearings on my WD are weeping grease, so I figure the seals need to be replaced. Is it as easy as repacking bearings on a trailer wheel?
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2011 at 6:13pm
I never repack any of my AC's front wheel bearings. I install a zerk on each and every hub I own and give them a few pumps every once in a while. Yeah all of the seals weep grease and have to be wiped clean once in a while. But yes, you would repack them as you would any other bearing; pack into the widest side till it oozes out the narrower side.
This page was generated in 0.172 seconds.
