Ca Cl vs. Rim Guard
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Topic: Ca Cl vs. Rim Guard
    Posted: 13 Apr 2011 at 9:02am
I like many of you on here have had rims rust out around the valve stem from calcium chloride.  Right now my main concern is one of my WD45s, I was wondering what your opinions are on whether to fix the rims replace the tubes and keep the chloride or should I consider replacing it with rim gaurd.  I have to break down the tires anyway to fix the rim but I am considering just replacing the tube and putting the chloride back in and then watching it carefully.  I figure it took fifty years to rust out the first time so if I watch it I should be able to keep the rims around for a while.  I was also considering painting the rim with a paint like por-15 which is supposed to be able to stand up to battery acid things of that nature and should slow any possible rusting.
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2011 at 9:47am
Ca Cl isn't a problem when contained.Just replace valve core every other year be fore they start leaknig.Right now I can get beet juice for about same money.
This page was generated in 0.190 seconds.
