TL-12 Won't move
TL12Larry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TL12Larry Quote  Post ReplyReply Direct Link To This Post Topic: TL-12 Won't move
    Posted: 12 Apr 2011 at 5:10pm
I've replaced the clutches, changed the fluid, adjusted the clutches all over the place, but it will not move...
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 5:21pm
 Did you check the air in the tire?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TL12Larry Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 5:31pm
No air, beer (in case I break down over a 1/2 mile from the house).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 5:37pm
You know there is a tire inside a drum in the driveline, I ain't just jerkin' your bobber. Go look and check it out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TL12Larry Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 6:56pm
We'll I really do appreciate your not jerkin' the ol' bobber...but where would I find the tire? And does it have a valve stem to add air?  I see the clutches through the small access panel and that's about it.  They appear to be engaging properly.   I can't find a valve to check fluid pressure either...
This thing was supposedly running and driving before the clutches were changed.
Thanks
iceberg210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iceberg210 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2013 at 10:36am
There may be a small sump filter that is clogged, the power steering system is run off the same fluid as the tranny is the steering working?
This page was generated in 0.149 seconds.
