possitive or negative ground
Sitesstables View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sitesstables Quote  Post ReplyReply Direct Link To This Post Topic: possitive or negative ground
    Posted: 12 Apr 2011 at 4:02pm
OK i am having the generator checked today and new wires made to go from generator to the regulator. Here is my question The wireing diagram shows a positive ground.. but the guy who had the D17 Series IV before me just hooked it up as negative ground.. So it this and issue or is it ok. When I poloize the the system will that work. Or does it need to be postive ground?
1965 D17 Series IV
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 6:32pm
   Is it 6 or 12 volt ?
Edited by Rfdeere - 12 Apr 2011 at 6:33pm
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 6:43pm
All of A-C's generator systems were originally positive ground. When you put it all back together, polarize the system. Polarizing is in simple terms telling the generator which pole is "hot" and "ground".
It will work either way. I've heard that the regulator will not work so well if it was originally pos ground and you switch it to neg ground. My experience has been it makes no difference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sitesstables Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 7:45pm
OK thanks I wondered if the polorizing would take care of the issue. I am having it all checked out since it seams to not be charging the battery. Even after been running for a long time it has to be jumped. The battery tests good. Someone said you can not use a 12V battery. But the guys at the electrical shop did not say anything and they deal with tons of old tractors and restore them selves.
1965 D17 Series IV
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sitesstables Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 7:46pm
They have a 12V battery in it. And I have read sometings that say the series IV is 12v I will know for sure in the morning
1965 D17 Series IV
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 8:20pm
I think all series IV D17's were 12 volt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 8:24pm
Yes D-17 Ser IV gas all had 12 volt battery.Believe all D-17 had 12 volt.Our 59 was factory and it had 12 volt.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 9:14pm
Some magnetic regulators were a little polarity sensitive from the choice of contact materials. Different materials for the points on the vibrating regulator unit cut cost but cut life with reversed polarity. Otherwise that type of regulator wasn't polarity sensitive.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 9:50pm
All D17 & D15 were 12V. Some D14 were 6V.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sitesstables Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 2:18pm
Just an update, I put new generator in and new regulater on last week. Went and put it back to positive ground and replorized everything. It was much simpler then I though and she is running well... Next up// a new manifold
1965 D17 Series IV
This page was generated in 0.031 seconds.
