Antifreeze in Oil on 8050 Help
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Topic: Antifreeze in Oil on 8050 Help
    Posted: 11 Apr 2011 at 8:09pm
Dad and I have a lot of decisions to make and need some help from you guys.  I pulled the drain plug on the 8050 to change the oil and about a thimble full of antifreeze ran out first.  Then i notice that there was moisture below the bypass tube and it was green and sticky.  It hasn't been using coolant and the oil wasn't milkey.  It's got right at 4000 hours and has never been apart.  So, there are two questions right away.
We talked to two neighbors that are diesel mechanics, they told us to run straight water with bars leaks because the water won't spin the bearings.  They both guessed a head gasket but said if it was a liner we would know in about 20 hours.
1st question.  would you run water and try to make it through planting and pray that we don't spin a bearing or tear it apart now and hope we get it back together in time?  We could get the crops in with about 50 hours of running time on that tractor.
If and when we rebuild, what would you do at that time.  I have heard about the M&w pistons that make it start better.   would you rebuild the pump/injectors at that time, it runs fine now.  what about the turbo, it's easy to change but is original.  I know there are a lot of aftermarket parts for these engines now.  we're open to change but don't need extra power and not willing to sacrifice reliability for an extra 10 hp.
We have a lot of experience rebuilding engines but this is our first time in a 426.  any help is appreciated.
Derek in Mo
Rogers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rogers Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 9:39pm
Derek,
I would tear it down now. If you wait you may get lucky and get through planting season, but if you don't you don't make planting season and spend more money on the rebuild. It is a tough call. When you are talking about something that affects your livelihood it is a tough call.
Basically it is a gamble. You take a chance and make planting season, or you take a chance and don't make planting season knowing that failure amounts to more cost. I am not generally a gambler unless I believe the odds are in my favor.
In this case there is no real way to know. I remember once having a truck start knocking where a mechanic said I could either bite the bullet and tear it down to find the problem or drive it like crazy and see what happened. I tore it down. The knock was on a main bearing. If I had taken the chance it would possibly have thrown a rod causing me to spend major money.
I know that I haven't given any real help, but sometimes you just have to bite the bullet. If you start quick a rebuild will probably not take that long, but gambling could lead to a longer period of the tractor being out of service which would not be good.
Think for yourself and be your own expert. Be willing to change your mind; however, willingness to change your mind doesn’t mean that you will. Blindly following any path is the pinnacle of insanity.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 10:22pm
HMMM....sure thing is tear down now but since it seems to be recent leak,may be little to no damage to brgs which would allow you to run straight water without fear.I don't know how much a 426 can tolerate.My 3406 Cat ran a full day with over a gallon of antifreeze in the oil and you couldn't see brg trouble at teardown.(9 gal sump) It's a gamble no doubt.You would love the M&W style pistons but they are expensive.The fuel system and turbo can be tended to any time later with little trouble but I like to have rods resized with new bushings honed to fit the new wrist pins and replace all valves with quality new ones.Valve height is important and needs to be in spec.Good to plane the head for flatness too.It all adds up and some question doing the extras but I only want to do it once.I put the new AGCO rod bolts in also even though some claim the originals aren't a problem.ARP built the new ones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 10:44pm
Yea, the minimal amount of antifreeze in the oil tells me that i caught it right away.  I know it is due for a rebuild, but if i do it now i will be under the gun to get it done.  if i can make it through planting, i can take my time and do it right.
I don't remember everything but I've heard people talk about reliance works and the nice work they do as well as advances in pump rebuilding.  i plan on keeping this tractor for a while and would like to do the proper research and build it the best i can.
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 11:25pm
Reliance price sounds high but it's reasonable.They put an inline A pump on.I did basically what they do and didn't save any money plus took way more time.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 6:57am
Here is how I would look at it, and Steve M kinda hit on it also.
You have three scenarios.
1. Tear it down now, if it takes a bit more time, you "may" plant a "FEW" days late.
2.  Risk it, start planting loose the crank, maybe a rod, or worse a block, then only part of your crop is in, now you are spending big money on repairs, and no crop to pay for it.  Plus now you have to limp the tractor in, get all the tanks off, unhitch the planer, all with a dead engine = time.
3.  Risk it and it runs the whole season. BIG RISK, you don't know how long it took to produce that thimble full of coolant.  If you run straight water, and watch the oil every four hours or so for clouding, and drain the water out every morning before starting it, it might work.  Depending on how the oil is looking, and what water comes out in the mornings, change the oil every few days?
I really want you to think about number 2.  It would probably really screw up the oportunity to take advantage of what looks to be a promising year in ag this year, looks like a perfect storm for great prices on grain.  I know it is hard to time repairs, they never happen at the right time, that's just the way farming goes.  You should be able to get all the parts you need for that rebuild very quickly, and if you and another guy are doing the work with reasonable days put in, in a fairly well equiped shop, it shouldn't take more than a week depending on what machine work you have done.
Looking for another block or crank could add days at the most critical time in the farming phase.  With all the late snow, and you know how early springs rains mess things up, you won't have a big window this year to plant.  I would hate to have my panting tractor down for two weeks in the middle of prime planting season, because I risked it, and put a rod through the block.
Sorry for the doom and glood, just my $.02
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 7:00am
Originally posted by wekracer wekracer wrote:
.....if i can make it through planting, i can take my time and do it right.
I almost forgot, my most important point, the difference between doing it right, and not, in this case is probably a total of 8-16 hours, most of it in cleaning, and machine work.  Not a very big price to pay now for assurance, and long term reliability.  Yes there are some dollar differances, but it sounds like you are willing to spend the right money to fix her properly later anyway.
Still in use:
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 7:27am
It does sound like a small amount of antifreeze that you found.
Pesonally I would fill it up with water and run it, and like they said check for water in the oil every morning, I suppose you could also drop the pan now and check a couple of bearings to see if they are pitted?
Also Since GM went to the Dexcool orange antifreeze they have not had any bearing failures associated with antifreeze. it is much safer on bearings. So you could switch over to that if you need an antifreeze.
Edited by Matt MN - 12 Apr 2011 at 1:21pm
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 8:05am
i would tear it down and get a new head gasket put in it. like others have said so what if you have to plant a few days later. its just good insurance to get it done now and out of the way. last thing you will need while planting is another item on your mind worrying if your engine is going to hold up and not take a crap on you. like others have said the injectors and turbo are items that you can do later. when you have the engine apart you can check the turbo your self. reach in with your finger and spin the turbo blades they should spin very nice and smooth. also you can check to see if the bearings are bad by trying to move the blades up and down.
cms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cms Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 9:51am
You most likely have the sleave leaking around the bottom of the block. This is very common on the ac since they dont have a coolant filter.
Craig from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig from IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 9:59am
I agree with CMS, those tractors are notorious for liner cavitation.  Craig
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 12:16pm
I would put water in it and plant with it monitoring oil close. It's not like it will work hard planting. Then you'll have all summer to rebuild it. A thimble full was all he found so it is a very minor leak. Also, I thought by the time the 8000's came out, they had coolant filters, just a matter of if it ever got changed.
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 12:28pm
While you have the pan off, rent or borrow a cooling system pressure tester and pressurize the system. See if you can pinpoint where the water is coming through. (liner o-rings, cavitated liners, maybe dripping from head gasket, perhaps the intercooler?) Personally, I would tear into it now. We both know you will be in it soon anyway. Just as well try to save what you can. What about a salvage yard engine in it until planting is done? Maybe it will burn some oil or be hard to start, but at least you will be saving your better engine to rebuild.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 12:59pm
The old "Pay me a little now or a lot later" scenario. I guess that's a tough call with needing to be in the fields. My first choice would be long block if you can swing it. My luck would be it would self destruct if I tried to push it...
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 2:01pm
My memory may be bad, but I thought coolant conditioners/filters were put on the inter-cooled engines in the 8000's.  It was also important to change them per the operating instructions or cavitation erosion would happen.
Edited by 427435 - 12 Apr 2011 at 2:02pm
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 4:09pm
Thanks for all the input.  dad put a pressure tester on the radiator today. it dropped from 7 pounds to 6 pounds in 20 minutes so it can't be that bad.  We're going to put Bar's Leaks in it and run straight water.  I can check the oil morning, noon and night and as long as it's not milky looking i don't think it's got enough to hurt anything.  It's got 4000 hours on it, so it's going to get freshened up after crops are in.
200farmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200farmboy Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 9:07pm
I maybe wrong but i think the 8050 had a water filter on it. I know the 8050 we bought new had a water filter on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 10:20pm
it does have a water filter on it.  we put the bars leaks stop in this afternoon and pulled it for about an hour.  after it cooled we put the pressure tester on it and it held at 7 pounds.  We're going to run it and keep a close eye on the oil.  If we have to tear it down now, it's going to be a couple weeks before we get parts and a month before we can run.  If i get half way through planting and have to shut down at least i'm half way through and not a month late getting started.  I'll keep you all posted on how it turns out.  thanks for all the input and keep the old girl in your prayers.
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 10:36pm
Why not park the 8050 in the shed and go buy a good older 7060 to run your planter?  When you're done planting/sidedressing&whatever else, sell the 7060.  In the meantime, you could be rebuilding the 8050.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2011 at 6:04am
The AC engines are known for throwing a rod due to cavitation cause it usually leaks right on the rod bearing. If the leak would miss the bearings it would tolerate the leak better. If it held pressure and you keep a close eye on it you might be OK through planting.
Wink
I am a Russian Bot
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2011 at 7:32am
hello everyone, this is my first post here
there was a 6080 local that was having the same problem, you could pressureise it and it would hold pressure all day, but get a small amount af antifreeze in the oil when it was run,  so it was torn down and rebuilt and still had the same problems, it was not the enjine but the oil coller, does this tractor have a oil cooler have you checked the oil cooler?
sorry to butt in but i hope that this might help you save some expence
