816 front hydrolic pump U joint
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Topic: 816 front hydrolic pump U joint
    Posted: 10 Apr 2011 at 5:23pm
Looking for NAPA of some other after market part number for the front hydrolic pump "U" joints
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2011 at 11:29am
If you take the old U-joint in they can measure up all the critical dimensions and come up with a replacement. They essentually need the bearing cup diameter, the cross dimension and the snap ring location to come up with a number.
