WTB: 12vdc NC relay |
Post Reply ![]() |
Russ-neia ![]() Silver Level ![]() Joined: 11 Sep 2009 Location: NE Iowa Points: 489 |
![]() ![]() ![]() ![]() ![]() Posted: 10 Apr 2011 at 2:28pm |
Working on a project and I need a half-dozen 12vdc normally closed relays capable of transmitting 5-10 amps. Can someone point me in the right direction for a part at NAPA or specific vehicle and use I can get some from a salvage yard? Prefer weather-tight case with spade or threaded-stud connectors. Thanks!
omahagreg ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Omaha, Nebraska Points: 2806 |
I don't have any specifics, but Radio Shack might have something as well.
Greg Kroeker
1950 WD with wide front and Freeman trip loader |
Roddo ![]() Orange Level ![]() Joined: 16 Jul 2010 Location: Brant, Ontario Points: 466 |
Pretty much any square 5 pin relay in a Ford vehicle will work for you. They usually have a map on the side that looks like this:
![]() 85 and 86 are your control side. If you want NC you connect power in to 30 and out from 87a. |
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 23796 |
Roddo's right on the money with the diagram.Try a 'foglight' relay,any autoparts place will have them, about $5 in the USA( $10 here in Canada..it's a 'freetrade' thing)PS ALL made in China too....
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 11918 |
If yer' thinking Automotive electrical, just think B&B. We have piles of SPST relays in stock if thats what yer lookin' for. 4 terminal and 5 terminal. Also have Marine style relays in stock. 30/40 amp rating and weathertite. Relay plugs, holders, modules, and our own relay panels up to 8 relays. Pretty much anything you may need. We have so much Automotive electrical stuff in stock, it'll make yer' head spin. No brag, just fact! . Drop a line if interested..... Steve@B&B |
Nathan (SD) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Day County SD Points: 1267 |
Normally closed means that when you put power to the relay the main circuit on the relay will go dead. That will be a odd one to find in 12V. Mouser.com has alot of electrical.
Brian Jasper co. Ia ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Nathan, see Roddo's post. That configuration for a relay is what Ford has used from the beginning of electric fuel pumps and electronic engine controls. A late 80's Ford vehicle fuel pump/ EEC relay fits exactly what Russ is looking for.
Thanks for the help guys! Roddo's schematic helped me immensely - I had seen it before on relays on equipment, but didn't stick in my mind that all of those relays had BOTH circuits. I looked around yesterday, and there are 12 of those relays just on our pull-type New Holland chopper. More are under the dash of my 8010 and in our skidloader. I, like Nathan, assumed that NC would be a rare find.
What I'm doing, is putting Ag Leader electric row unit clutches on my planter. They need power to open the clutch/shut off the row. The GPS monitor I'm hoping to use is configured to turn power off to shut off the device (like sprayer valves), so I needed a way to reverse the on/off functions. Thanks once again for pointing me in the right direction!
Post Reply ![]() |
